Timmah Posted June 17, 2019 Share Posted June 17, 2019 Spotted this when looking for a gearbox replacement: Does it look like it has an LSD? Cheers! Quote Link to post Share on other sites
Patches Posted June 17, 2019 Share Posted June 17, 2019 On 6/17/2019 at 5:08 AM, Timmah said: Does it look like it has an LSD? Cheers! Expand Yes that to me looks like an OEM LSD Gearbox. It has the lsd outside of the box on the drivers side, standard gearboxes do not have this. Be warned that you will need to source a shorter drivers side driveshaft as they are shorter because the lsd pokes out the side. These drive shafts would have came with the car which had the LSD box fitted but can be quite difficult to find. Quote Link to post Share on other sites
Timmah Posted June 17, 2019 Author Share Posted June 17, 2019 On 6/17/2019 at 9:48 AM, Patches said: Yes that to me looks like an OEM LSD Gearbox. It has the lsd outside of the box on the drivers side, standard gearboxes do not have this. Be warned that you will need to source a shorter drivers side driveshaft as they are shorter because the lsd pokes out the side. These drive shafts would have came with the car which had the LSD box fitted but can be quite difficult to find. Expand Cheers dude! I did realise the drive shafts are different, but did not realise they may be next to impossible to find here. Quote Link to post Share on other sites
Patches Posted June 17, 2019 Share Posted June 17, 2019 On 6/17/2019 at 11:03 AM, Timmah said: Cheers dude! I did realise the drive shafts are different, but did not realise they may be next to impossible to find here. Expand Might be worth seeing whoever has the box if they can supply the shaft with it. They come up from time to time but generally get sold with a box rather than on their own Quote Link to post Share on other sites
karl. Posted June 18, 2019 Share Posted June 18, 2019 you also need to get the rear mount (black bracket) and you also need the rear alloy mount that bolts onto the car. Quote Link to post Share on other sites
Timmah Posted June 19, 2019 Author Share Posted June 19, 2019 On 6/18/2019 at 1:20 PM, karl. said: you also need to get the rear mount (black bracket) and you also need the rear alloy mount that bolts onto the car. Expand Good spotting.. I think this idea may be down the drain. The seller has none of those parts, nor the drive shafts Quote Link to post Share on other sites
