Sign in to follow this
Giannis
Glanza boost issue
As title....i am a stock ep91 glanza owner
When I push the throttle it boost fine(three lights on tacho an a lot of power and torgue) utlil 5000 5500 rpm the boost lows down (two lights on tacho and less power and torgue)
Any suggestions
Thanks
Share this post
2 hours ago, akyakapotter said:
If it's completely stock it will restrict boost in 1st and 2nd gear untill you bypass the hi low function.
Cheers nick
It is nothing to do with restriction....it happens to all gears
Thanks
Share this post
44 minutes ago, BMX-RIG said:
Weak actuator?
This is my first suspicion
Does a cracked manifold affects?
Thanks for reply
Share this post
I am currently going through this same problem, I installed a boost gauge just to be sure and it confirms that I am losing boost as soon as that last light comes off, boost drops with it. From factory its 9psi and I am getting that and just as Giannis said around 5k it drops to about 5-6psi.
Please any suggestions.
Share this post
