Sign in to follow this
GalantEvo
EP82 15" 8Jx25
Specs above. Would they fit on an EP82 without rubbing? Archwork is not a problem as it's a track car.
Currently running 6,5x+37, and if I go to 8x+25 that means 7.1mm closer to the strut, and 31.1mm more poke. I know the outside will be fine (except the strut I don't know), but it's the inside that I'm worried about.
Edited by GalantEvo
Share this post
Im running 15x8 et20 currently. with a 5mm spacer on the front
Its wide. Arch work will definitely be needed, also depends what tyre you want to run. if you want to run a 205, then it'll be tight.
That is with rear and front camber and +25mm front wings with 195/50 AD08Rs
Assume you are running stock calipers?
Share this post
Running stock calipers yes. Might have plans to upgrade for the future, but that won't be soon.
I'm going to be running 195/50/15 tires.
What do you mean by archwork? Just roll the inside lip, or actually widen the entire arches? I'm not afraid to roll the guards but anything beyond that or plastic fender flares is a bit much for some wide wheels.
Edited by GalantEvo
Share this post
Ive got wider wings up front, never tried with stock so cant comment
back i am running 3 degrees of camber and have the inner lip rolled flat and sealed with seam sealer.
EP82 has an advantage that you have a slightly narrower rear beam so you do have a bit more room in the rear aches
Share this post
Just curious as to how you added camber in the rear. Cut and welded the ends of the beam?
Share this post
