Hi Guys,
First time poster here so please bear with me.
A little background info that will probably be relevant:
Car Specs:  1996 EP91 Glanza V
So, I bought the car recently, and it had an engine management light on which showed the code for knock sensor.
I took off the inlet manifold, throttle body, inter cooler and fuel rail to gain access to the broken plug on the sensor.
Replaced the sensor and plug and put everything back together in the process my PCV valve snapped in half, so replaced that also.
Now the car starts up fine, no issue revving in neutral, however once under load the car chokes at around 3k RPM (See attached video)
I'm not 100% sure about the hoses connecting to the throttle body if they are in the correct spots as I stupidly didn't mark them.
I marked all the plugs and those are back in right.
Any ideas what could be causing this issue?
Cheers.
Hey,
Thanks for the replies,
Luckily I put the hoses on correctly,
However I did miss the MAP sensor hose,
That completely fixed it!
Thanks again.
Matt
