Charlie Thompson Posted April 7, 2020 Posted April 7, 2020 Hi guys, currently looking for a new exhaust system for my glanza V. is anybody running the tuning developments system and whats there thoughts on it? http://www.tuningdevelopments.uk/popup_image.php?pID=3325 cheers😎 Quote
SKINY Posted April 8, 2020 Posted April 8, 2020 Looks nice, you could pick up a good 2nd hand Blitz etc system for a few hundred too Quote
Charlie Thompson Posted April 8, 2020 Author Posted April 8, 2020 I've bit the bullet and bought one today, should hopefully arrive tomorrow 😀 Quote
akyakapotter Posted April 8, 2020 Posted April 8, 2020 I'd like one only if and when I go stand alone. Good piece of kit. Quote
Jwood91 Posted May 25, 2020 Posted May 25, 2020 I bought one of these a while back with a resonator from TD. It sounds great and is built really well. I've had a few compliments about the sound The only problem I had with it is that the rear curve section ended up actually touching the axel slightly (not good when it was vibrating!) I couldnt get it to sit proud and not rub so ended up putting some heatproof silicone on to absorb the vibration and protect the metal which wasn't ideal but more to do with my fitment than the design I'm sure. Guessing by the date of your post its arrived for you now? Im not sure whether it could be simple as using some different rubber hangers but interested to know if you had the same issue and what you did if so? Quote
Charlie Thompson Posted May 27, 2020 Author Posted May 27, 2020 On 5/25/2020 at 4:53 PM, Jwood91 said: I bought one of these a while back with a resonator from TD. It sounds great and is built really well. I've had a few compliments about the sound The only problem I had with it is that the rear curve section ended up actually touching the axel slightly (not good when it was vibrating!) I couldnt get it to sit proud and not rub so ended up putting some heatproof silicone on to absorb the vibration and protect the metal which wasn't ideal but more to do with my fitment than the design I'm sure. Guessing by the date of your post its arrived for you now? Im not sure whether it could be simple as using some different rubber hangers but interested to know if you had the same issue and what you did if so? Yeah I had exactly the same issue and I tried everything to rectify it. In the end I took the exhaust off and heated it up where it was touching then brayed it with a hammer to flatten it so it didn't touch. Fits a treat now plus you cant see where I've had to hit it Quote
akyakapotter Posted May 28, 2020 Posted May 28, 2020 On 5/25/2020 at 4:53 PM, Jwood91 said: I bought one of these a while back with a resonator from TD. It sounds great and is built really well. I've had a few compliments about the sound The only problem I had with it is that the rear curve section ended up actually touching the axel slightly (not good when it was vibrating!) I couldnt get it to sit proud and not rub so ended up putting some heatproof silicone on to absorb the vibration and protect the metal which wasn't ideal but more to do with my fitment than the design I'm sure. Guessing by the date of your post its arrived for you now? Im not sure whether it could be simple as using some different rubber hangers but interested to know if you had the same issue and what you did if so?  15 hours ago, Charlie Thompson said: Yeah I had exactly the same issue and I tried everything to rectify it. In the end I took the exhaust off and heated it up where it was touching then brayed it with a hammer to flatten it so it didn't touch. Fits a treat now plus you cant see where I've had to hit it Spoke to Mike this morning he's curious why you guys didn't contact him regarding the hitting the beam they are fitting one this weekend so will have a look when fitting it. Cheers nick Quote
Charlie Thompson Posted May 28, 2020 Author Posted May 28, 2020 1 hour ago, akyakapotter said:  Spoke to Mike this morning he's curious why you guys didn't contact him regarding the hitting the beam they are fitting one this weekend so will have a look when fitting it. Cheers nick I was happy with the exhaust that's why I've never said anything, I expected to have to make slight modifications to get it to fit properly with it been a 3" exhaust. Im simply just replying as to how I rectified mine. Quote
akyakapotter Posted May 28, 2020 Posted May 28, 2020 Ah that's cool I really want one for mine but it's not really needed just a want lol Quote
Charlie Thompson Posted May 28, 2020 Author Posted May 28, 2020 3 minutes ago, akyakapotter said: Ah that's cool I really want one for mine but it's not really needed just a want lol I would definitely recommend one, best sounding system I've heard 😎 Quote
Jwood91 Posted June 8, 2020 Posted June 8, 2020 On 5/27/2020 at 9:43 PM, Charlie Thompson said: Yeah I had exactly the same issue and I tried everything to rectify it. In the end I took the exhaust off and heated it up where it was touching then brayed it with a hammer to flatten it so it didn't touch. Fits a treat now plus you cant see where I've had to hit it Ahh Thanks for replying dude! i need to check back more often I may do the same to mine as it sounds like a bit more of a long term soloution. Glad to hear it wasn't just me at least haha. nice to hear you're enjoying it!    On 5/28/2020 at 12:53 PM, akyakapotter said:  Spoke to Mike this morning he's curious why you guys didn't contact him regarding the hitting the beam they are fitting one this weekend so will have a look when fitting it. Cheers nick Same as with me I was happy with the exhaust and when I've spoken to Mike briefly he's been more than helpful . I put it down to my fitment.. would love to know how he got on though  Quote
