Sign in to follow this
ChineseMafia
4efte powere steering pump on 5E
ok guys
curious to know how persons who don`t delete powering steering on their Gts or Glanzas mount the FTE powering pump on their 5E engines ?
Share this post
i used some bolts about 15mm longer and 15mm of washers i think to space it out.
Share this post
not sure i understand
https://ibb.co/dbfxna
the bracket in the above photo does not line up with the original bracket because of the block hight difference
Share this post
Not that bracket its the one which is behind the pump which bolts to the engine.
Edited by Bean
Share this post
