1 hour ago, Bean said:
i used some bolts about 15mm longer and 15mm of washers i think to space it out.
not sure i understand
https://ibb.co/dbfxna
the bracket in the above photo does not line up with the original bracket because of the block hight difference
Not that bracket its the one which is behind the pump which bolts to the engine.
Edited by Bean
  • 2 months later...
