ChineseMafia Posted April 28, 2020 Posted April 28, 2020 ok guys curious to know how persons who don`t delete powering steering on their Gts or Glanzas mount the FTE powering pump on their 5E engines ? Quote
Bean Posted April 28, 2020 Posted April 28, 2020 i used some bolts about 15mm longer and 15mm of washers i think to space it out. Quote
ChineseMafia Posted April 28, 2020 Author Posted April 28, 2020 1 hour ago, Bean said: i used some bolts about 15mm longer and 15mm of washers i think to space it out. not sure i understand https://ibb.co/dbfxna the bracket in the above photo does not line up with the original bracket because of the block hight difference Quote
Bean Posted April 28, 2020 Posted April 28, 2020 (edited) Not that bracket its the one which is behind the pump which bolts to the engine. Edited April 28, 2020 by Bean Quote
Faiyaz.123 Posted July 17, 2020 Posted July 17, 2020 ive run into the exact same problem splits the belt. Quote
