lickmycrit Posted May 9, 2020 Share Posted May 9, 2020 my car glanza started this loud ticking louder than the normal injector ticking and i cant figure it out it.. i read some older posts about the unplugging the ICV to see if any changes or cracked manifold ect but none of those seem to be the issue have this crappy video for audio Quote Link to post Share on other sites
Claymore Posted May 9, 2020 Share Posted May 9, 2020 Did it happen out of the blue or has it had any work recently? Quote Link to post Share on other sites
lickmycrit Posted May 9, 2020 Author Share Posted May 9, 2020 Yeah just out of the blue while I was driving. I started it today and it had no clicking on a cold start but once it warmed up and I drove for couple mins the ticking came back Quote Link to post Share on other sites
lickmycrit Posted May 9, 2020 Author Share Posted May 9, 2020 2 hours ago, Claymore said: Did it happen out of the blue or has it had any work recently? Yeah just out of the blue while I was driving only work done was a oil change about a week ago I started it today and it had no clicking from a cold start but once it warmed up and I drove for couple mins the ticking came back Quote Link to post Share on other sites
Claymore Posted May 10, 2020 Share Posted May 10, 2020 Check the right grade of oil was used, although it seems like an extreme result even if it is the wrong grade of oil. Unfortunately it could be many things. So it may be a process of elimination, based on the video sound. With the engine off Start with a visual inspection of the engine bay components, any damaged / worn belts, worn bearings in alternator / Power steering pump. Have any vac hoses popped off / split. If the exhaust manifold has a crack it should be visible with black soot showing or a leaking gasket should also be traceable. Quote Link to post Share on other sites
lickmycrit Posted May 11, 2020 Author Share Posted May 11, 2020 22 hours ago, Claymore said: Check the right grade of oil was used, although it seems like an extreme result even if it is the wrong grade of oil. Unfortunately it could be many things. So it may be a process of elimination, based on the video sound. With the engine off Start with a visual inspection of the engine bay components, any damaged / worn belts, worn bearings in alternator / Power steering pump. Have any vac hoses popped off / split. If the exhaust manifold has a crack it should be visible with black soot showing or a leaking gasket should also be traceable. the alternator is new i used a 5w30 oil my belts look fine and the power steering looked fine vac lines looked fine i did 2 starts with no belts and only alternator belt on then i put the power steering/ac belt on then it came back so im thinking it might be the ac's pulley or bearing or something? but i was wondering if i could get a smaller belt and only have it on the power steering so i can isolate the ac completely and see if the noise goes away but im not sure how id find the size belt to even attempt that cause i wont be able to tension it id have to get something a tad smaller so it'll be tight over the power steering so it doesnt fly off but idk if im overthinking it or not im a bit lost with the noise its driving me insane Quote Link to post Share on other sites
Claymore Posted May 11, 2020 Share Posted May 11, 2020 It sounds like you may be closing in on the issue. 😀 Some people delete the A/C on these cars and therefore need a shorter belt for the Crank - Power steering pulley. I believe they use the one from the 4efe engine used in the starlet with no A/C. This belt is tensioned from an adjuster on the power steering pump. Google searching for this should reveal belt length required. The noise in the video sounds like air being pumped to me. Does your A/C work? Is there any damage to the pipes or components of the system where the pump could be sucking and blowing air causing the noise? Quote Link to post Share on other sites
lickmycrit Posted May 11, 2020 Author Share Posted May 11, 2020 2 minutes ago, Claymore said: It sounds like you may be closing in on the issue. 😀 Some people delete the A/C on these cars and therefore need a shorter belt for the Crank - Power steering pulley. I believe they use the one from the 4efe engine used in the starlet with no A/C. This belt is tensioned from an adjuster on the power steering pump. Google searching for this should reveal belt length required. The noise in the video sounds like air being pumped to me. Does your A/C work? Is there any damage to the pipes or components of the system where the pump could be sucking and blowing air causing the noise? Yeah the A/C works perfectly I haven't noticed any damaged pipes for the AC I'll have to take another look later it's 3am atm haha Quote Link to post Share on other sites
Claymore Posted May 11, 2020 Share Posted May 11, 2020 (edited) Fair enough Sound like either the A/C pump or PAS pump as you have said that the noise is not present until the belt for these items is in place. If a/c works I doubt it could be leaking bad enough to make an air pumping noise. Might be A/C clutch or bearing making the noise though. Keep at it. Edited May 11, 2020 by Claymore Quote Link to post Share on other sites
lickmycrit Posted May 12, 2020 Author Share Posted May 12, 2020 15 hours ago, Claymore said: Fair enough Sound like either the A/C pump or PAS pump as you have said that the noise is not present until the belt for these items is in place. If a/c works I doubt it could be leaking bad enough to make an air pumping noise. Might be A/C clutch or bearing making the noise though. Keep at it. I just wanted to be sure so I tired running it without the belt and went for a drive and sure enough it's still there I'm stumped 😞 I reread what I first posted im using 5w20 think switching to 10w40/30 would help at all? Quote Link to post Share on other sites
Claymore Posted May 12, 2020 Share Posted May 12, 2020 5w20 is a bit thin really. Most people seem to run 10w40 in the UK or maybe 5w40 for colder climates. Oil isn't expensive compared to other fixes so I'd change it if it was my car. Quote Link to post Share on other sites
lickmycrit Posted May 12, 2020 Author Share Posted May 12, 2020 11 hours ago, Claymore said: 5w20 is a bit thin really. Most people seem to run 10w40 in the UK or maybe 5w40 for colder climates. Oil isn't expensive compared to other fixes so I'd change it if it was my car I just changed it and I still got the ticking 😭 Quote Link to post Share on other sites
Claymore Posted May 13, 2020 Share Posted May 13, 2020 Well look on the bright side, it now has the correct grade oil and you have eliminated another possibility. Believe it or not that's still progress. 👍 Quote Link to post Share on other sites
