Got 3 of these. Having a clearout!
Left Radiator - Has a bracket welded on front to mount under the front light support bar. Little stealthier...
Right Radiator - Has the top hose port moved over to the right. To alloy the radiator to be moved to the left to get a Boost Pipe  up the inside of the chassis leg. Cuts out a lot of pipework-route and improves spool!
Triple Core. Used, but perfect working order.
Rad 1 (Extra Bracket) - £30 Posted
Rad 2 (Moved Port) - £30 Posted
Rad 3 (Perfect) - £50 Posted
Paypal or Bank Xfer is fine.
I am based in Gainsborough, Lincolnshire, if you want to collect?
