Faiyaz.123 Posted June 7, 2020 Posted June 7, 2020 (edited) As the topic I'm having trouble with sticky throttle cable. I'm unsure now if it's the throttle body itself giving up. Wanted advise i have a zisco intake stock throttle body. Should I go with another throttle body ? And if so then which one? I have a haltech elite 1500 which supports drive by wire. So is there anyone who can provide a setup which has been done and tested before ? Your help would be highly appreciated Edited June 19, 2020 by Faiyaz.123 Quote
RobSR Posted June 7, 2020 Posted June 7, 2020 There is not a PnP solution as such. Fiske are doing an inlet currently to suit a Bosch Motorsport 74mm DBW but this may be too big for most setups. The pedal was easy as its got a Tilton pedal box, so again you’d need to mod an OE pedal to fit. It’s all fairly simple to do but you’ll mostly have to piece the parts together yourself. Quote
Faiyaz.123 Posted June 19, 2020 Author Posted June 19, 2020 Maybe in should start by replacing the stock throttle body and cable . What throttle body can I use as a replacement? Quote
Patches Posted September 6, 2023 Posted September 6, 2023 EP Wiring now offer parts for fitting DBW Quote
