As the topic
I'm having trouble with sticky throttle cable.
I'm unsure now if it's the throttle body itself giving up.
Wanted advise i have a zisco intake stock throttle body.
Should I go with another throttle body ? And if so then which one?
I have a haltech elite 1500 which supports drive by wire.  So is there anyone who can provide a setup which has been done and tested before ?
Your help would be highly appreciated
Edited by Faiyaz.123
There is not a PnP solution as such.
Fiske are doing an inlet currently to suit a Bosch Motorsport 74mm DBW but this may be too big for most setups. The pedal was easy as its got a Tilton pedal box, so again you’d need to mod an OE pedal to fit.
It’s all fairly simple to do but you’ll mostly have to piece the parts together yourself.
  • 3 years later...
