SKINY Posted August 15, 2020 Posted August 15, 2020 7 hours ago, RoyalDutchie said: corsa c sxi discs are the correct ones in the UK. Some advertise them as 256mm while the same are 260mm in the Netherlands which is kinda strange. This plus upgraded Vauxhall discs are cheap as chips bud Quote
Sam44 Posted August 15, 2020 Author Posted August 15, 2020 26 minutes ago, SKINY said: This plus upgraded Vauxhall discs are cheap as chips bud Now we are talking. All looking good. Quote
mycars12 Posted August 16, 2020 Posted August 16, 2020 if you want super baller brakes the celica 4 pots should bolt up but youd need to find a rotor that works Quote
Sam44 Posted August 16, 2020 Author Posted August 16, 2020 (edited) 4 hours ago, mycars12 said: if you want super baller brakes the celica 4 pots should bolt up but youd need to find a rotor that works Now we are talking what model and year are these from, I know Brad on here is running Celica dual acting caliper possible 4 pots, I'm not to sure. I'll look on his MK1 build. Brad is quite but really very clued up. I think he's even running a gto bigger master cylinder. Edited August 16, 2020 by Sam44 Quote
mycars12 Posted August 17, 2020 Posted August 17, 2020 Should be the gt4 i believe. They are on the expensive side if your on a budget. Quote
SKINY Posted August 17, 2020 Posted August 17, 2020 Good pairs are 4-500 now Sam Set sat here for the Dina when I get the time to look into it A mate here runs them on his glanza, 16" wheels and 27mm spacers come to mind, lot off messing but can be done. Quote
Sam44 Posted August 17, 2020 Author Posted August 17, 2020 PpInteresting yeh I've looked them up thy are big. I'd be interested in seeing a list of parts needed. I'll message Brad for info on his MK1 see what he has done. Thanks guys for all and any input/information, I'm starting to get to grips with these little machine's. Quote
