Timmah Posted November 18, 2020 Share Posted November 18, 2020 Hey guys, My little EP91 failed it's WoF (MoT for you UK folk) on a few things, ones that i will get a mechanic to sort out, but I'm pretty keen to try figure these out: - Brake lights flicker when indicators are going The brake light bulbs are.. cheap and nasty LEDs, but could a poor ground be causing this? I will try some proper bulbs first - High stop light is on when the park lights are on This, I couldn't replicate when I got home.. so I'm not sure what to make of this. Any ideas? Quote Link to post Share on other sites
Bean Posted November 20, 2020 Share Posted November 20, 2020 Yep i would check your grounds im sure this happened on my teg after i sprayed the engine bay and the grounds needed cleaning up due to the paint. Quote Link to post Share on other sites
Timmah Posted November 21, 2020 Author Share Posted November 21, 2020 On 11/21/2020 at 7:02 AM, Bean said: Yep i would check your grounds im sure this happened on my teg after i sprayed the engine bay and the grounds needed cleaning up due to the paint. A few months ago I actually re did a few of the earths in the engine bay, I'll recheck those. I found one earth in cabin on the drivers side, just where the bottom of the door is, but it looked nice and clean, I should actually traced the cables back come to think of it, oops. Quote Link to post Share on other sites
JxckGlanza Posted January 27, 2021 Share Posted January 27, 2021 Does sounds like grounds issue. Have you got to the end of it yet? Quote Link to post Share on other sites
Timmah Posted January 28, 2021 Author Share Posted January 28, 2021 10 hours ago, JxckGlanza said: Does sounds like grounds issue. Have you got to the end of it yet? I didn't in the end, I put back some halogen bulbs and left it at that Quote Link to post Share on other sites
JxckGlanza Posted January 28, 2021 Share Posted January 28, 2021 4 hours ago, Timmah said: I didn't in the end, I put back some halogen bulbs and left it at that Orrrr I didn’t read it properly lol. You may need a resistor to use the led lights. Quote Link to post Share on other sites
