Nilz90 Posted April 26, 2021 Posted April 26, 2021 Hi guys, I’m struggling to locate what each of these wires are for on a ep82 gt turbo 1994. Is someone able to help me identify them please. Quote
daniel_g Posted April 26, 2021 Posted April 26, 2021 1 - coolant sensor 2 - coolant gauge on dash cluster 3 - for AC sensor on thermostat housing, you no longer have it, there is a bolt there instead. (Irrelevant) 4 - cat temp sensor (irrelevant) Should be a green coolant temp sensor for the green plug 1, your sensor is grey. Does it fit? Quote
daniel_g Posted April 26, 2021 Posted April 26, 2021 There are a few different thermostat housings. Yours might not match that loom. Quote
Nilz90 Posted April 26, 2021 Author Posted April 26, 2021 1 hour ago, daniel_g said: 1 - coolant sensor 2 - coolant gauge on dash cluster 3 - for AC sensor on thermostat housing, you no longer have it, there is a bolt there instead. (Irrelevant) 4 - cat temp sensor (irrelevant) Should be a green coolant temp sensor for the green plug 1, your sensor is grey. Does it fit? Thanks Dan, I wasn’t sure either so 1 plugs into the coolant temp sensor but it’s grey and green. For 2 where is the other end for this to plug into or is it meant to be on the thermostat housing? The thermostat housing is from a glanza V and my looms are ep82 Quote
daniel_g Posted April 27, 2021 Posted April 27, 2021 2 - should be in the thermostat housing aswell. It is only for the cluster temp gauge. You could fit an aftermarket coolant temp gauge. Quote
Nilz90 Posted April 27, 2021 Author Posted April 27, 2021 (edited) On 4/27/2021 at 7:51 AM, daniel_g said: 2 - should be in the thermostat housing aswell. It is only for the cluster temp gauge. You could fit an aftermarket coolant temp gauge. Managed to get hold of the correct thermostat housing so will replace it. Do you know where this single wire goes that is going over the master cylinder? I’ve just earthed it, is that right? Edited April 28, 2021 by Nilz90 Quote
Nilz90 Posted July 20, 2021 Author Posted July 20, 2021 Does anyone know if my coolant temp sensor on my gt is grey and the plug is green could it cause any issues or this is fine? Also my fan is on constantly could this be due to the fan switch sensor being green and the plug being grey? The A/C pressure sensor is plugged in. Quote
