tucka Posted June 4, 2008 Posted June 4, 2008 well basicaly i work for hullcity football club and becuase we reached the premiership i receive a bonus at the end of this month of £1100 from my work!!! ;) so i want to spend this on the car on perfomance mods, as my engine is pritty much stock apart from the apexi power fc ecu and optional boost controller and hks exhaust hi silent power, and a rex tmic,so want some more engine upgrades before i get it mapped.my turbo oil seals have gone so i either want to run a ct9hybrid setup and get a new mani and fmic. or maybe if i could find a good turbo kit thats in my price range? i dont get the money till the 28th of this month so got some time to find the right kitso what do you guys recomend?cheerstucka Quote
Ryno Posted June 4, 2008 Posted June 4, 2008 just to check, you got a decent suspension & brake set-up yeah? good tyres? had a service recently?[Edit: Damn you and your fast fingers Rick] Quote
tucka Posted June 4, 2008 Author Posted June 4, 2008 what handling/braking mods you got?just to check, you got a decent suspension & brake set-up yeah? good tyres? had a service recently?[Edit: Damn you and your fast fingers Rick]got kyb special sr dampers front and rear, ridin on tien springs, 3 point rear strut brace, front strutbrace, front anti roll bar, 3g groved disks and green stuff pads, last serviced 2weeks ago, tyres are like new. Quote
Ryno Posted June 4, 2008 Posted June 4, 2008 good lad ;) think your on the right tracks with the new Mani and FMIC, obviously thats all depending on what turbo route you want to go so have a look at what the traders are offering atm!might me worth looking into an up-rated fuel pump too before the mapping!you keeping the std air box?maybe braided brake lines and master cylinder stopper too? ;) Quote
tucka Posted June 4, 2008 Author Posted June 4, 2008 good lad ;) think your on the right tracks with the new Mani and FMIC, obviously thats all depending on what turbo route you want to go so have a look at what the traders are offering atm!might me worth looking into an up-rated fuel pump too before the mapping!you keeping the std air box?maybe braided brake lines and master cylinder stopper too? ;)yeah i want to do evrything right first time, yeah i thought i would buy a uprated fuel pump and maybe bigger injectors next payday then mappin. no i prob relcoate the air filter to the front somewhere.just been lookin for some kits on here and came across thishttp://www.ukstarletclub.com/forums/index....showtopic=11731it would be the full amount spent and i wouldnt be able to get the fmic yet, but looks an awsum peice of kit. what you reckon? Quote
montanajr Posted June 4, 2008 Posted June 4, 2008 Go for a hybrid! I would! lol.Get some bigger injectors (7MGE ones) if needed, walbro fp, front mount air filter, fmic, mani, de-cat, exhaust and get it setup ! Should be good, with your ECU you could probably max out a hybrids output, so 220-230hp atf. K26 would be epic. But wouldn't really be able to get the most out of it on standard internals (220-230hp atf is "safe" I'd say). Quote
Ryno Posted June 4, 2008 Posted June 4, 2008 arn't they quite laggy too? seem to remember the last starlet i went in with a K26 set-up took about 10mins to spoil up ;) Quote
tucka Posted June 4, 2008 Author Posted June 4, 2008 Go for a hybrid! I would! lol.Get some bigger injectors (7MGE ones) if needed, walbro fp, front mount air filter, fmic, mani, de-cat, exhaust and get it setup ! Should be good, with your ECU you could probably max out a hybrids output, so 220-230hp atf. K26 would be epic. But wouldn't really be able to get the most out of it on standard internals (220-230hp atf is "safe" I'd say).yeah they is alot of options to considor, but i think hybrid is the route im lookin at takin, just need to find the right hybrid at the right pricearn't they quite laggy too? seem to remember the last starlet i went in with a K26 set-up took about 10mins to spoil up ;)lol ;) thats kinda off puttin Quote
tucka Posted June 4, 2008 Author Posted June 4, 2008 apologies that was a k3 not a K26 lolah fair doos, so k26 is still a good option then Quote
StarletRick Posted June 4, 2008 Posted June 4, 2008 for a grand id get all the base mods done. so fuel regulator. fmic. better mounts. decent piggy back. EBC itll give you a good platform to start some proper modding the next time money comes rolling in. Quote
Ryno Posted June 4, 2008 Posted June 4, 2008 whats he need a piggy back for when he's got a power FC? ;) Quote
tucka Posted June 4, 2008 Author Posted June 4, 2008 whats he need a piggy back for when he's got a power FC? ;)maybe because im gonna hybrid a power fc so its a super ecu!! lol crazy worldi think im gonna go for hybrid,mani,fmic,bigger injectors and fuel pump, if i can get all this in my budget i will be a happy man lolbut im still open to suggestions of diffrent kits Quote
ecksjay Posted June 4, 2008 Posted June 4, 2008 you'll need to spend double your budget to get the most out of a k26 mate, forget that one unless you wanna spend a good amount of what the car's actually worth.You wont need a fuel pump, 255lph walbro's etc are MASSIVE overkill for starlets, the stock pump is more than ample, or you could just get the OEM pump from a skyline or 200sx or something for a few quid (20quid or so from one of the forums) and it'll be more than enough for stock internals. all these people that say you need a walbro have no idea, at the end of the day its a 1.3 and you'll struggle to max out the stock pump unless you're whipping the engine out. Quote
tucka Posted June 4, 2008 Author Posted June 4, 2008 you'll need to spend double your budget to get the most out of a k26 mate, forget that one unless you wanna spend a good amount of what the car's actually worth.You wont need a fuel pump, 255lph walbro's etc are MASSIVE overkill for starlets, the stock pump is more than ample, or you could just get the OEM pump from a skyline or 200sx or something for a few quid (20quid or so from one of the forums) and it'll be more than enough for stock internals. all these people that say you need a walbro have no idea, at the end of the day its a 1.3 and you'll struggle to max out the stock pump unless you're whipping the engine out.ah right cheers for the info dude!! Quote
RobSR Posted June 4, 2008 Posted June 4, 2008 i thought the main reason why people changed to a walbro was that the standard one will be rediculously old, and has a higher chance of failing... Quote
DetomasoNick Posted June 4, 2008 Posted June 4, 2008 i wouldnt spend all that money, wont the club ask for it back when you get relegated????? ;) i jest, this is a bit of a pointless post really as the posts above it are all pretty good and ive got nothing of any help to say lol Quote
keirz Posted June 4, 2008 Posted June 4, 2008 mani and hybrid, plus rear arb and anti lift kit. that should see good gains for the money............or spend it on beer and women! Quote
tucka Posted June 4, 2008 Author Posted June 4, 2008 i wouldnt spend all that money, wont the club ask for it back when you get relegated????? ;) i jest, this is a bit of a pointless post really as the posts above it are all pretty good and ive got nothing of any help to say lollol ;) mani and hybrid, plus rear arb and anti lift kit. that should see good gains for the money............or spend it on beer and women!well i know my misses wants to spend some of it towards a holiday! but yeah been thinkin about gettin a rear arb for a longtime, whats the anti lift kits like? Quote
ecksjay Posted June 4, 2008 Posted June 4, 2008 More likely to fail? have you ever heard of a toyota fuel pump dying? i know i haven't. either way, 255's are overkill, massive overkill. if they're used in 500bhp skylines, then they're rather overkill on a starlet.the holiday sounds like a good idea mate. personally i'd stick it in an isa or something and sit on it for a while, put it towards something ube like a house deposit or a bloody good holiday - the misses would surely like either of those.Arb's do make such a difference, ideally you want noticable increases for as little as possible, listen to the guys above, except for the ones that are talking shit. you have my permission to kick them in the scrot. Quote
Guest Enzo Posted June 4, 2008 Posted June 4, 2008 ideally you want noticable increases for as little as possible, listen to the guys above, except for the ones that are talking shit. you have my permission to kick them in the scrot.totaly id go on this also, keirs also has the right idea,my wee sugestions, a decent bucket seat and aftermarket stearing wheel, both mods will help you increase your hold over the carmaybe a short shift kit and some decent aftermarket pedals biased toward heal and toeing, or you could spunk your setup on some monty brakes and an emanage l oldecisions decisions Quote
Glanza_Ragger Posted June 5, 2008 Posted June 5, 2008 Forget the k26 on standard internals.For that budget, you would easily reach the 200 mark, and a tad over depending how far you push a hybrid.But thats the route i took, i only forged mine because i shattered a rod in my previous one.If you want drivability, and response..Stick to a hybrid or maybe a TD04.anything larger and youre looking at lag which makes it less fun to drive unless youre dragging it or driving on large tracks.With the power fc and a hybrid you should get a decent figure with the rx top mount.A decent hybrid will set you back half of that budget alone.. so Quote
tucka Posted June 5, 2008 Author Posted June 5, 2008 totaly id go on this also, keirs also has the right idea,my wee sugestions, a decent bucket seat and aftermarket stearing wheel, both mods will help you increase your hold over the carmaybe a short shift kit and some decent aftermarket pedals biased toward heal and toeing, or you could spunk your setup on some monty brakes and an emanage l oldecisions decisionswell i have already got my self a pair of bride seats and takata harnesses, momo steering wheel, razo pedals (everyone has them lol) plus im shockin at heal and toein, more of a left foot brake man. Forget the k26 on standard internals.For that budget, you would easily reach the 200 mark, and a tad over depending how far you push a hybrid.But thats the route i took, i only forged mine because i shattered a rod in my previous one.If you want drivability, and response..Stick to a hybrid or maybe a TD04.anything larger and youre looking at lag which makes it less fun to drive unless youre dragging it or driving on large tracks.With the power fc and a hybrid you should get a decent figure with the rx top mount.A decent hybrid will set you back half of that budget alone.. sowell i have managed to source a hybrid on tgtt for £395 which is pritty good price! just after a fmic now think il get one of them hdi ones, as i get massive heat soak from the tmic! Quote
StarletRick Posted June 5, 2008 Posted June 5, 2008 whats he need a piggy back for when he's got a power FC? ;)haha, i totally didnt see that. he should get one anyway, because they are the winz ^^ Quote
