Ryan Posted June 7, 2008 Posted June 7, 2008 I am looking at a wheels here and i want to no if they will fitthey are 4 hole 15-inch wheels 6.5JJ PCD114.3 offset +39 would they be ok ?? Quote
Idrees Posted June 7, 2008 Posted June 7, 2008 Nope, as the others have said they will not fit.You want 4x100 PCD and offset of around ET37-ET40, well thats what offset fit best on the Starlet in my opinion. Quote
Ryan Posted July 2, 2008 Author Posted July 2, 2008 so these would fit thenSize: 14"Width: 6JET: 38PCD: 4X100 Quote
Ryan Posted July 2, 2008 Author Posted July 2, 2008 set of WedsSport RS5's. Need a other set of wheels while the ones i have on now are being refurbished Quote
SiCaln Posted July 2, 2008 Posted July 2, 2008 do you tho? have u tried a good set of shocks and springs, i had collies and changed em for trd shocks with rsr springs Quote
SiCaln Posted July 2, 2008 Posted July 2, 2008 u can get some adjustable dampening ones but not height Quote
Ryan Posted July 2, 2008 Author Posted July 2, 2008 i wud like height adjustment so i cud drop the car down onto the 14's i have on now. i have trd springs in at the min but its not low enough at the back Quote
Markoos Posted July 2, 2008 Posted July 2, 2008 do you really NEED coilovers unless you're goin on track days n stuff? Quote
Bourkey Posted July 2, 2008 Posted July 2, 2008 Have to agree with Mark there. They will shatter your back in to a million pieces on our wonderful UK roads. ....If some came up silly cheap i probably still have them though as they are mint.Bourkey Quote
Ryan Posted July 2, 2008 Author Posted July 2, 2008 how much of a drop would you get on a good shock and spring setup. will the handling be just as good as coilovers. Was looking a D2's because i was told jap coilovers were harsh Quote
Glanza_cl Posted July 2, 2008 Posted July 2, 2008 how much of a drop would you get on a good shock and spring setup. will the handling be just as good as coilovers. Was looking a D2's because i was told jap coilovers were harshwith a good pair of shocks and 40mm spring you are set, like others have said unless you are going to go on tracks days etc there isn't much point- although if you are supper picky and want it even lower and want to change the camber, damping etc then coilovers are the obvious choice. but daily driving shocks and spring are more than enough good handeling, nice ride. Quote
