StarletRick Posted June 17, 2008 Posted June 17, 2008 ive got 10w30 atm. which is fine. but ive used 5w in the past. it all ends up 30vis when hot so i dont care to much about the cold weight tbh. Quote
NightSpirit Posted June 17, 2008 Author Posted June 17, 2008 As I couldn't wait for you..I've bought 6 quarts of Royal Purple Racing 41 10W40 shizzle Also bought a few of the Sard Mag+ filters from Japan and a few of the Mag+ sump nuts.Just need to buy the A048s and get hi-Spec to make me some new front discs and I'm there...in Germany...in 8 weeks...dead....in the armco....broken, on fire. Or as we're doing the Stelvio pass on the way back, I could be at the bottom of the alps...dead...awesome Quote
NightSpirit Posted June 18, 2008 Author Posted June 18, 2008 that's me...Mark 'protect your engine as best you can' Rehorst-Smith Quote
StarletRick Posted June 18, 2008 Posted June 18, 2008 even the stock motor uses 30weight oil. the difference between 40 and 30 is enough that you can "feel" the engine running smoother. Quote
NightSpirit Posted June 18, 2008 Author Posted June 18, 2008 shutit..anyway, I've ordered Toyo R888s, came down to budget. Set of 4, 195/50/15 medium compound...£256 delivered. Quote
StarletRick Posted June 18, 2008 Posted June 18, 2008 youre just gutted that you ordered the gayer oil. ^^also, those triple 8s will be toast by the time you drive there, race and come home. but itll be SO fun... Quote
Callan Posted June 18, 2008 Posted June 18, 2008 LOL....my avon cheapo £5.99 jobbies are replicas of proxes....they are awesomes,they even grip in 3rd gear which is amazingthey are shit.pure disgustingness.dont grip even in dry when its 450degrees...avon fur teh looses Quote
Liam_D Posted June 18, 2008 Posted June 18, 2008 Them R888's was cheap where did you get them from??I agree with Rick though they will be pretty much screwed after the 'ring, have you got any other rubber to drive back home on?? Quote
NightSpirit Posted June 18, 2008 Author Posted June 18, 2008 at Cal you pikey scumbag.The R888 will be toasted if I have my way with them for sure. And no, I have no other rubber for the return leg...or the Alps...awesomeThat price is from CamSkill, £64 a tyre with vat and shipping. I looked at importing from Yoko in Japan but the costs took the piss. Quote
GeeUK Posted June 19, 2008 Posted June 19, 2008 I use Redline oils, Royal Purple are good too...used them before.I currently use TRD filters...did use a SARD when I was running the engine in.And if you want to buy Royal Purple, then buy direct...like I do :sJust type Royal Purple in Google UK. Quote
