BenV Posted July 22, 2008 Posted July 22, 2008 when i give my car the beans and full boost is used ive noticed that theres a bit of black smoke (kinda like a mist) coming from the back. does this mean my turbo is on its way out? Quote
ecksjay Posted July 22, 2008 Posted July 22, 2008 if the turbo's dying its usually blue smoke, as it'll be burning oil.black smoke 'could' mean the turbo aint as fresh as it could be, but it could also be something else... Quote
BenV Posted July 22, 2008 Author Posted July 22, 2008 cheers fella, i'll double check the colour of the smoke, its kinda hard when your in the car looking out of the rear view mirroris there any other checks i could do? Quote
ecksjay Posted July 22, 2008 Posted July 22, 2008 check your oil levels mate, if you're dropping any oil at all. Quote
starlybruiser Posted July 22, 2008 Posted July 22, 2008 may be something wrong with the fuel injection?? as black smoke is usually too much fuel, or your air filter could be blocked up so check that too, hope this helps, starlybruiser Quote
ecksjay Posted July 23, 2008 Posted July 23, 2008 my starlet never puffed out black, only white (just a bit of condensation when cold as it was decatted).however, the s14 is a chimney, they all do it. looks like its rediculously overfuelling, but its just what they do. Quote
paul w Posted July 23, 2008 Posted July 23, 2008 You will know when your turbo has died, there will be no doubt of the colour! Just ask the guy behind you when he gets out of the smokescreen http://www.turbotechnics.com/docs/turbo/faults.htmhttp://www.turbotechnics.com/docs/turbo/faq.htm Quote
