Guest Enzo Posted August 7, 2008 Posted August 7, 2008 hey i just need to clarify somethingim abit confused about raster and vector imagesam i right in saying a raster image is stored in a jpeg formatand vector as a gif format?apart from that is there anything else that realy distinguishes between raster and vector,hopefully someone can help me Quote
SiCaln Posted August 7, 2008 Posted August 7, 2008 nah not quite geo, a vector file is made up of triangles so is therefore like an ai, illustrator format, a raster style is pixelsied so therefore like cmyk/rgb art hence jpg gif etc Quote
Guest Enzo Posted August 7, 2008 Posted August 7, 2008 yes i understand what your sayingbut if i created a vector image what format should i save it in? Quote
gaz Posted August 7, 2008 Posted August 7, 2008 Raster = bitmap images i.e JPEG, TIFF..which are lines of pixels that will add or remove pixels depending on how you size it and usually ruin the picture.Vector = I think these are mathematical equations instead of pixels allowing the shape to rendered to any size or form.Depends what you created it in, some people use the term 'vector' even in Photoshop. Which is incorrect although i think you can export them as Illustrator files somehow now in CS3You would have to Create it in something like Indesign or Illustrator or Corel draw and save it as an EPS or a PDF these are both good for print. But you may have to adjust some things on the PDF settings. Save it to JPEG for web if its an Image. Images should be saved as TIFF for inputting in documents for print. Quote
SiCaln Posted August 7, 2008 Posted August 7, 2008 but if i created a vector image what format should i save it in?Like Gaz has said what program has this been made in? Quote
Guest Enzo Posted August 7, 2008 Posted August 7, 2008 thats usful so far guys thanx alot ;)the image has been created in fireworks Quote
gaz Posted August 7, 2008 Posted August 7, 2008 Yeh it will prob have to be a JPEG mate.Gifs are good for little animations and small graphics that don't require much information such as icons and areas of blank colour - on the web. They are not really good for photo's mate as they cant contain as much information. Quote
SiCaln Posted August 7, 2008 Posted August 7, 2008 if you are using it online you would be fine with gif or jpg, if print you can still use there or tiff, psd if its multilayer Quote
gaz Posted August 7, 2008 Posted August 7, 2008 Yeh they can be used on photos. They will load much faster if say it was used as a banner but wont look as good as JPEG. Quote
