Someone had a 4WD EP82 with the front wheels not connected, 4EFTE engine.
Sucked though.
Judging by the guys username he has a rwd starlet and obviously thinking about 4efte'ing it and he would need a rwd drive box to suit it :mellow:
As said im pretty sure they use a 4age box on some conversions?
hay yea sorry if my intentions arnt clear. But glad to see some people know about the old ones. wana to get more power than my 100hp 4k engine is making.
would go 4age but the engine is a solid block and is too much weight for the front end.
im not to sure about the engine weight of the 4efte but i know the W55 is an all allie houseing?
also the smaller displacement engine would be better suited for the car as i would like to keep the olriginal rear end with a LSD.
any help would be greatfull
A
like I said If i'm right in thinking they use the same bell housing bolt pattern as the E series engines go for an ae86 box
ye use a 4age mate, the weight is neglegable, considering the convenience of being able to use the 4age and all the parts that come with it. its quite a common conversion, so would work well.
either that, or go SR20, and go spinning about all over the place uncontrollably.
ive actually seen a few F20C engines in old KPs. they are apparently awesome. theres soem US company that make the mounts etc to run the conversion. they are REALLY light aswell and wubs the revs.
and kp's are all about the revs.
  • 4 weeks later...
