DavidAshton Posted September 10, 2008 Posted September 10, 2008 As soon as i got the Glanza i thought the brakes were shite they seemed to be getting worse but i wasnt too sure. Now they are pants....I can fully push the brake pedal a good 2" now until it feels like something metal is stopping it, like when you push the clutch fully down....When the pedal is fully down it does pretty much nothing over 30 then when it finally starts doing something it makes the car weave (only when going fast)....Now ive been told the brakes probably need bleeding does that sound right? Ive got some new ebc green stuff pads on order to try and help things aswell....If so how do i bleed the brakes will it be obvious when i get the wheels off and if it is the case of air in the system how could it have got this bad?ThanksDavidedit: car had brand new brakes and pads fitted less than a month ago when i picked it up Quote
Asad Posted September 10, 2008 Posted September 10, 2008 This is just a guess but One of the calipers could be seized thus giving uneven braking? brakes need bleeding?something wrong with the balancing of the front 2 tyres (causing the weaving)? Quote
Sparky Posted September 10, 2008 Posted September 10, 2008 Sounds like air in the system if it has new padsThey need bleeding by the looks, preferably when bleeding the brakes you need two people, one to pump the brakes while the other person drains the fluid. Quote
Jozinobi Posted September 10, 2008 Posted September 10, 2008 What brake discs are u running David?I had the same feeling of pedal on metal, I had this with the standard brakes.To me its the limitations of a standard brake setup.I also wouldnt run uprated pads (i.e ebc greenstuff) with standard discs, I would use at least 10 grooves for better heat and brake dust dissipatation.I would also recommend installing a cusco bmcs, it will do wonders for positive pedal feel.For a future proof setup, go for a twin pot setup. Then you will be sorted for later on when you start to mildly mod.Thats imho. But before you do anything, make sure to check all functions of the current brakes inc bleeding etc as mentioned above.Joz Quote
DavidAshton Posted September 10, 2008 Author Posted September 10, 2008 Can anyone quickly explain the process of bleeding brakes? Do i have to put new fluid in or will the air just come out first?Thanks for all the advice so far...Also im running standard brakes and pads Quote
WallaceGlanza Posted September 11, 2008 Posted September 11, 2008 Bleeding the brakes on these cars is a pain in the arse, I've done it numerous times and not got it perfect yet! However it is probably your problem.The basic procedure is:Get a friend to help and sit in the car, check the brake fluid level and make sure the system never runs dry, top as your doing the bleeding with fresh fluid.Start from the wheel furthest from the master cylinder and work closer, so passenger rear, driver rear, passenger front then driver front. Get your friend to pump the brake pedal ten times then hold the pedal down (bestto put a piece of wod under the pedal as it will fall to the floor when the bleeder is open and can damage the master cylinder seals), then crack open the bleeder screw (8mm spanner) and the fluid should spurt out, then close the screw and your friend can release the pedal.Ideally you should do this with a clear tight fitting hose over the bleeder screw so you can see the fluid coming out, then repeat the pumping and releasing until there are no air bubbles in the fluid and fresh fluid is flowing through if your changing it. Keep an eye on the fluid level in the cylinder and work your way around the car until done. Its straight forward enough but hard to get perfect. Quote
Driver Posted September 11, 2008 Posted September 11, 2008 when your greenstuff pads come david giz a shout and we can brake them when we fit the pads Quote
molovin Posted October 8, 2008 Posted October 8, 2008 when your greenstuff pads come david giz a shout and we can brake them when we fit the padsSounds like a seized capilar. I had this problem a week ago a bit of heat and it should release itself its just a builed up of rust in my exeprince. Garage will charge 1 hours labour for it Quote
