pistolpete559 Posted October 10, 2008 Posted October 10, 2008 hi guys having a bit of a drama getting discs and pads all round for my ep91 which i dont think has abs! toyota want nearly £300!!!! ;) what diameter do i need as there are several different sizes. it a 1996 ep91 glanza turbo i live in n.ireland. any help at all would be greatly appericated ;) . Quote
Guest Enzo Posted November 24, 2008 Posted November 24, 2008 there are only one size for the ep91 and your best bet would be starletgtturbo.co.ukor toytuning for them, they are both traders on this site man Quote
Jozinobi Posted November 25, 2008 Posted November 25, 2008 Your best bet right now Pete is to call Dave Burwash as he has the fastest response time right now.Call him on 07852 295221, tell him what you need and he will sort you out with the correct parts.I'd recommend 3G 10 groove or 3G 20 groove rather than standard items and also some aftermarket brake pads to match.You may as well upgrade for a similar if not cheaper price than what you would have bought from Toyota.Its not ideal to use standard brakepads with grooved discs so make sure not to skimp.His website is www.starletgtturbo.co.uk where you can check out what is available.Hope this helps.Joz Quote
Asad Posted November 25, 2008 Posted November 25, 2008 I rang up the part shop for some1 i worked with not long ago who had an N/A, she needed the discs n they said there were 2 sizes avaliable....n then rang else where they said there was only one size Quote
SiCaln Posted November 25, 2008 Posted November 25, 2008 does SR hav different callipers to every other model? or is it later models have bigger callipers, ie same as Glanza's where as early ones are smaller Quote
Asad Posted November 25, 2008 Posted November 25, 2008 I could have sworn they do (i remember some1 swapping them with a white SR n a N/A) n they had diff brake calipers.....i think SR has bigger calipers aswell as glanza n other models have the small ones. Quote
Bourkey Posted November 25, 2008 Posted November 25, 2008 As far as i know the SR caplipers are the same size as Glanza ones. They are on mine anyway. I have also heard somewhere that the very later models of the n/a Starlets have the SR/Glanza brakes also.Bourkey Quote
Asad Posted November 25, 2008 Posted November 25, 2008 Hmmmmmmm so there is two diff disc sizes....????P.s bourk what are caplipers? Quote
Bourkey Posted November 25, 2008 Posted November 25, 2008 ^^^ hohohohoho They are the metal things the brake pads go in . And yes there are two sizes. Dub Se7en had the smaller ones at one point then changed them for the bigger calipers and disks.Bourkey Quote
pistolpete559 Posted November 25, 2008 Author Posted November 25, 2008 cheers boys and girls, i phoned dave got the 10grove 3g with mintex pad for the front and std setup for the rear, the nice hoses toytuning where doing for the group buy and hey presto, it will put you through the windscreen if you so much as think brakes great job and at nearly the same price as toyota wanted for std all round!!!! Quote
Jozinobi Posted November 25, 2008 Posted November 25, 2008 Glad you got sorted Pete Sounds like a very satisfied customer to me.Joz Quote
StarletRick Posted November 25, 2008 Posted November 25, 2008 ive got a twinpot setup at home i dont need. it poops on the uprated disc/pad combo... pm me if youre interested. Quote
SiCaln Posted November 26, 2008 Posted November 26, 2008 i can confirm that its an awesome setup Quote
Jozinobi Posted November 26, 2008 Posted November 26, 2008 X2 - If you want a noticeable caliper upgrade the change from the smaller ones to the later calipers wont cut it. Go for the twinpot calipers, they are a good balance between cost and effectiveness.Joz Quote
