de em-b is what i run on my ep,
ul also need the boost pressure sensor +harness and ignition harness if your going for 250bhp(power to weight ratio would be insaine!)
at that power your going to need to uprate your
  • diff
  • clutch
  • injectors
  • turbo
  • manifold
  • decat
  • oil and waterlines for turbo
  • boost controller
ps thred moved could you please make sure you have a look over all the technical sections and post in the relevent one please
i just want management cabable of doing it so if i so choose to push the extra miles i dont have to buy it twice?
is the basic good or not worth it an i should be investing in something else?
Im pretty sure its the ultimate which you want then......but as some1 said on another thread its all about the mapping if its not mapped right its nothing more than controller or something along the lines of that lol
Emanage blue will be fine for upto 250bhp, the ultimate has more features and can do a finer tune but the blue is still good, I'm running it and putting out 190bhp on the stock ct9.
Its very good for the price as long as the person mapping it is good too, thats whats more important.:p
I'm a bargain hunter so I got mine brand new off ebay for £200, with the ignition and injector harness's.
To get a good tune from the emanage you need the two harness's above as it gives more adjustability (the harness's only cost 15quid each anyway), also if you planning on running abve 1 bar you also need the greddy 3 bar pressure/map sensor.
As I said the tuner is also a very important part so make sure there is someone you can take the car to who will be able to do a good job of mapping it for you, also depending on the tuner you may need to get the support tool and cable for the emanage which is just the program to put on the laptop.
I made that power with these mods:
Stock CT9A @ 15psi
Autofixed FMIC
Apexi Filter (Mounted behind the grill)
Road Runner Manifold
Blitz Decat
Custom straight through ss 2.5 inch cat back exhaust
HKS Actuator
NGK Iridium Spark Plugs
NGK Blue Leads
Walbro Fuel Pump
SARD RRFPR
SARD R2D2
GReddy Emanage Blue
GReddy Profec E-01
Aircon removed
:p
  • 2 weeks later...
emanage blue will do it mate. im running the ultimate 291bhp tho. the ultimate has more features compared with the blue.
theres a few people on tgtt and uksc that run emanage blue making 185bhp-275bhp
  • 1 year later...
WallaceGlanza,
I saw your setup and i was wondering,cause i'm about to order a EMB, but i want to go 250bhp safe on stock internals is that possible?
But i want to go 200bhp and i'm really driving to send it 250bhp.
My car specs Glanza 97:
Racing Airfilter
Supra fuel pump: About to go walbro 255L
TRD Leads
Iridium sparkplugs heat range 7
Turbonetics MBC
CT9
Uprated the OEM wastegate
FPR
TMIC about to HDI FMIC
And here is my question,
Obviously i need to install some gauges.
Wich one do i need for the setup that i want to go for?
Cause i have an A/F digital gauge but i think it's missing something, i'll be putting some pic's of the gauge in a bit.
Could you give me some advice on what more i need to be done for the setup that i want?
For the EMB i already read what i need for my car or do i need more more items for the EMB?
Thanks in advance
Tha Dragon
Here i have the A/F Gauge.
Give me some advice would that one be good for my setup?
EMB will be fine for that dude, im currently running 1.4bar on a TD04 on stock internals and injectors, and im only on EMB. Ide like EMU however bank says no at the moment so EMB will have to do :wacko:
Mine was mapped by Ricky from Race-tech on here and has been at 1.2 at over a year on this and 1.4 for last 2 month.
