im going to take off my cat at the weekend and replace it, im i right in thinking its an easy but fiddaly job?
what size is the Lambour sensor tool i need 22mm? i know you can use a spanner but would prefer the proper tool
yeh im sure its 22mm? n i dont think there is a "proper" tool just drench it with WD and use a open ended spanner and twist the rest of it off by hand
do the job in decent weather/under cover and allow plenty of time for grazed knuckles and swearing :p
Its is a giant twat of a job to do, there is a lip round the back part of the lambda sensor so if you dont have a perfect size spanner its pretty impossible to get off. If you still have aircon and the stadard efi pipe be prepared to swear a lot. Id also remove the rad so you have a bit more to work, even then its still a twat. Also watch out for boost creep after you fit it. Had to turn my actuator down to below .6 bar and it creeps upto .8 bar.
its not that hard to do. just make sure you have some decent extenders for your ratchet...and a proper lamba sensor tool will make it alot easier...or just chop the side out of a 22mm socket
