JM_16v Posted November 6, 2008 Share Posted November 6, 2008 im going to take off my cat at the weekend and replace it, im i right in thinking its an easy but fiddaly job?what size is the Lambour sensor tool i need 22mm? i know you can use a spanner but would prefer the proper tool Quote Link to post Share on other sites
Asad Posted November 6, 2008 Share Posted November 6, 2008 yeh im sure its 22mm? n i dont think there is a "proper" tool just drench it with WD and use a open ended spanner and twist the rest of it off by hand do the job in decent weather/under cover and allow plenty of time for grazed knuckles and swearing Quote Link to post Share on other sites
DavidAshton Posted November 7, 2008 Share Posted November 7, 2008 Its is a giant twat of a job to do, there is a lip round the back part of the lambda sensor so if you dont have a perfect size spanner its pretty impossible to get off. If you still have aircon and the stadard efi pipe be prepared to swear a lot. Id also remove the rad so you have a bit more to work, even then its still a twat. Also watch out for boost creep after you fit it. Had to turn my actuator down to below .6 bar and it creeps upto .8 bar. Quote Link to post Share on other sites
WallaceGlanza Posted November 7, 2008 Share Posted November 7, 2008 I took my cat to a garage and got them to remove both sensors for 10quid, mine were absolutely solid and had to be heated with a blow torch for ages before they budged. Quote Link to post Share on other sites
RobSR Posted November 7, 2008 Share Posted November 7, 2008 its not that hard to do. just make sure you have some decent extenders for your ratchet...and a proper lamba sensor tool will make it alot easier...or just chop the side out of a 22mm socket Quote Link to post Share on other sites
StarletRick Posted November 7, 2008 Share Posted November 7, 2008 buy a cheap socket and use an angle grinder to open up the side so you can put the wire out there. job done. Quote Link to post Share on other sites
