Decat - Lamba Sensor Tool
yeh im sure its 22mm? n i dont think there is a "proper" tool just drench it with WD and use a open ended spanner and twist the rest of it off by hand
do the job in decent weather/under cover and allow plenty of time for grazed knuckles and swearing :p
Its is a giant twat of a job to do, there is a lip round the back part of the lambda sensor so if you dont have a perfect size spanner its pretty impossible to get off. If you still have aircon and the stadard efi pipe be prepared to swear a lot. Id also remove the rad so you have a bit more to work, even then its still a twat. Also watch out for boost creep after you fit it. Had to turn my actuator down to below .6 bar and it creeps upto .8 bar.
