lobotomy Posted April 7, 2006 Posted April 7, 2006 When your engine management light comes on it means something is wrong. Ok so now you need to go out to your car and;Go into the engine bay and open the fuse/diagnostic box (little black box on the left-hand side of the engine bay) And the underside of the lid will show you the pin layout.Bridge pins TE1 and E1 (with a paper clip or bit of wire)Turn ignition on (but don't actually start the car)The engine management light will start to flashIt will flash say 4 times **** then a short pauseIt will then flash say once * This means error code 41 ie. Idle speed probThe management light will then start flashing another error code (they may be more than one fault) or have a short pause and repeat the same code over againThen refer to the list above or the diagram below to see what the error is Quote
SiCaln Posted March 21, 2010 Posted March 21, 2010 Just found this on another site, thought it may be of some use:Code | Signal Diagnosis and Common Trouble Area1 System OK2 MAP Sensor or Circuit3 Ignition Signal from Amplifier4 CTS/Circuit6 RPM Signal or Circuit7 Throttle Position Sensor (TPS) or Circuit8 ATS/Circuit9 Vehicle Speed Sensor/Circuit10 Cranking Signal or Circuit11 A/C Switch or Circuit12 RPM SignalNo G or NE signal present for 2 seconds during cranking Open G circuitOpen, short in G or NE circuit. Distributor ECU 13 RPM signalNo NE signal for 50msec at 1000rpm. Open G circuitOpen, short in G or NE circuit. Distributor ECU 14 Ignition No IGF signal to ECU for 4 consecutive IGT signal during engine running Open/short in IGF/IGT signal from Igniter to ECU Igniter malfunction ECU15 Starter Signal Circuit Coil pack wires16 ECT Control Signal or Circuit21 O2 sensor Open/short in heater circuit of Oxygen (O2) sensor for 0.5 secondsAmplitude of O2 sensor reduced to 0.35-0.70V continuously for more than 60 seconds O2 sensorVacuum sensorECU 22 Water Temperature Sensor no signal at THW Water temperature sensorECU 24 Intake Air Temp sensor no signal at THA Intake air temp sensorECU 25 Air/Fuel mixture Lean Oxygen (O2) sensor output in less than 0.45 volts for at least 90 seconds when O2 sensor is warmed and 1500 rpm or above. Open injector circuitLack of fuel pressureIgnition systemVacuum sensorO2 sensorECU 26 Oxygen (O2) Sensor Rich Signal or Circuit27 Oxygen (O2) Sensor/Circuit28 Oxygen (O2) Sensor/Circuit31 Vacuum SensorNo signal at Vacuum sensor (PIM)Vacuum sensor to ECU32 Vane Airflow Sensor or Circuit33 ISCV (Idle speed control valve)Open or short in ISCV circuitISCV Valve 34 Turbo Pressure Signal or Circuit35 Turbo Pressure Signal or Circuit41 Throttle Position Sensor (TPS)No signal for 0.5 seconds or more at ignition ON. (VTA) ECU 42 Vehicle Speed Sensor (VSS)No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm.For 8 seconds or more. ECU 43 Starter No starter signal to ECU when cranking in TEST mode.Terminal STA on ECUStarter signal circuitStarter relayIgnition switch 47 Throttle Position Sensor (TPS) or Circuit51 Switch Condition Signal displayed when A/C is on when TE1 and E1 connected in test mode A/C switchAccelerator pedal, cableECU52 #1 Knock SensorNo KNK1 signal to ECUKnock sensor looseMalfunctioning knock sensor 53 #2 Knock SensorNo KNK2 signal to ECU Knock sensor loose Malfunctioning Knock Sensor 54 Turbo Intercooler Signal or Circuit55 Knock Sensor or Circuit Quote
