warde Posted April 9, 2006 Share Posted April 9, 2006 how much boost can you put through the standard turbo safely with no mods on board Quote Link to post Share on other sites
dac69er Posted April 9, 2006 Share Posted April 9, 2006 about 12psi or whatever level fuel cut is. with no mods you wont boost any higher im afraid. Quote Link to post Share on other sites
SiCaln Posted April 9, 2006 Share Posted April 9, 2006 not a good way to look at it mate id take the time to sort out other bits before u up th eboost it may be a quick power increase, but can also lead to a quick drainig of money due to having to fix problems Quote Link to post Share on other sites
warde Posted April 9, 2006 Author Share Posted April 9, 2006 cheers for that i'm looking at a galant vr4 front mount that my brother has in his garage tommorow along with looking to purchase a blitz exhaust and air filter and boost controller to acompany the boost gauge and other gauges is there anyone local to northants that you know stocks gmax lowering springs as this deperatly needs doing as wellis this about all i would need to run around 12 psi Quote Link to post Share on other sites
lobotomy Posted April 9, 2006 Share Posted April 9, 2006 Is your exhaust just going to be cat-back? You might find just adding these couple breathing mods will make it boost to about 12psi+ without using any form of controller (MBC/EBC/Bleed valve)You also might find you'll hit fuel cut though. Quote Link to post Share on other sites
warde Posted April 12, 2006 Author Share Posted April 12, 2006 no exhaust will be full decat system may even look at a screamer pipe over time Quote Link to post Share on other sites
Sparky Posted April 12, 2006 Share Posted April 12, 2006 Screamer pipe? ive heard alot about these lately but do not no what they do or what they are for.Someone please enlighten meSparky Quote Link to post Share on other sites
scutch0 Posted April 13, 2006 Share Posted April 13, 2006 look here mate.http://www.ukstarletclub.com/forums/index.php?showtopic=42 Quote Link to post Share on other sites
Sparky Posted April 13, 2006 Share Posted April 13, 2006 WOW wish i could have one on my car!!!!! Quote Link to post Share on other sites
lobotomy Posted April 13, 2006 Share Posted April 13, 2006 A screamer pipe will fail your MOT as you are venting exhaust gas straight to atmosphere. You can get dump pipes that re-introduce the exhaust gas back into the exhaust system further away from the turbine wheel which will have the same benefits as a "screamer pipe" but no boeing747 scream at full boost. Quote Link to post Share on other sites
