  • Replies 322
  • 6 months later...
few update pics after fitting some new stuff, got the bc coilover's there set to the lowest at the front and about another inch to go o the back yet, fitted a whiteline panhard rod which we had to cut down and tube the inside and re-weld with 95mm cut out of it, got a new fuel tank which now hold 12 gallon, pink cruise gearknob, carbon cooling panel,
and a few new stickers for the back:rockon:
ahh dude what happend there then?,
thanks for the comments
i sliped on the dancefloor (someones spilt drink) and my ankle went over on its side and swolen up within a few mins, one of the door staff took me to kettering hospital :)
were did you get your carbon fiber bonnet from gaz??
  • 2 months later...
how did you get the rears so low on the bc's? As mine wouldn't go that low or did you loosen off the spring rate?
my rear suspension turrets have ben modified so I can drop it like it's HOT!!!!!!!!
Sparky if you would come down I would of gave you a spin out in it, all people have to do is ask and I will take ya for a spin :p
