Lukey_B Posted January 5, 2009 Posted January 5, 2009 EP91 N/A...Takes ages to heat up... and doesn't really go that warm at all...any ideas? Quote
Dan Evans Posted January 5, 2009 Posted January 5, 2009 on ya dials, ul have half cold, half warm, wen you turn it from cold to warm, it flicks a switch that converts the air to hot, either its broke, the fuse may be broke or could be something serious.have you tried running the car for 10mins without putting the heating on, then after its warmed up switching the heating on?? Quote
Lukey_B Posted January 5, 2009 Author Posted January 5, 2009 yeah... tried that - it's really shit though LOL...any other ideas? Quote
Asad Posted January 5, 2009 Posted January 5, 2009 Whats the temp gauge like? could be a blockage in the system coolant condition?....it can only be the dials if you turn them and you dont hear the noise of it switching + dont feel it diverting air. Quote
Dan Evans Posted January 5, 2009 Posted January 5, 2009 flusss your cooling system rad etc, try that Quote
Steve GT Posted January 5, 2009 Posted January 5, 2009 yer that happened to mine had fuk all coming throughjust drained it flushed all the pipes out and filled it up again and it did the trickworth a shot Quote
Asad Posted January 5, 2009 Posted January 5, 2009 Seems like the best thing to do first....i`d replace the thremostat while your there (cheap as chips and saves headache later if other problems arise). Flush everything rad,coolant reserve,hoses the lot....then top up with decent coolant.Good luck let us know how you get on i `ve got that to do aswell not in a hurry mine likes to burn my face off when its at temp Quote
Steve GT Posted January 5, 2009 Posted January 5, 2009 hmmmm if the thermostat was broke wouldn't the engine temp go sky high thoughbut as he said its definiatly worth doing while youre doing it Quote
Asad Posted January 5, 2009 Posted January 5, 2009 Its just a precaution buddy, if anything kicks up later then you know its defo the water pump/belt Quote
Steve GT Posted January 5, 2009 Posted January 5, 2009 yer true as you said its worth doing anyway Quote
Asad Posted January 6, 2009 Posted January 6, 2009 Lol you can also use this as an excuse to replace the hoses with sexy samco ones.... Quote
Asad Posted January 6, 2009 Posted January 6, 2009 Lol its all ideas i wanted to do but...i have made my choices for the future 0.o hes got a green one me likes...i`d get the black ones or the British racing green as it resembles our car colour nicelyhttp://www.samcosport.com/uk/available_colours.asp Quote
Lukey_B Posted January 8, 2009 Author Posted January 8, 2009 cheers for the help guys. drove home tonight from work. and the temp. guage ROCKETED! so just going to check it over and put some new coolant etc in...will that POSSIBLY solve the problem of my heaters being too cold? and how much is a thermostat goin to cost me? big job etc?cheersLuke Quote
Dan Evans Posted January 8, 2009 Posted January 8, 2009 piece of piss to fit mate, cost you pennies......drain the system, swap the thermostat put a water hose threw the rad etc, then reconnect and fill it back up bud, take you bout 40mins, well thats how long it took me Quote
Lukey_B Posted January 8, 2009 Author Posted January 8, 2009 will let you know if i manage to blow my car up in the process cheers guys!!! Quote
Lukey_B Posted January 12, 2009 Author Posted January 12, 2009 OK, so i totally flushed the radiator out, and refilled it with good coolant etc. and it got SLIGHTLY warmer. so now when i'm driving to work on those shitty mornings... i can see the bottom 2 inches clearly, everything else is covered in "mist"... any other ideas? I'm not sure whether it would be the thermostat... because it does seem to be pouring some hot air out... just not enough?? Quote
Lukey_B Posted January 12, 2009 Author Posted January 12, 2009 fuck.bugger it. up for sale £0.01 any takers? Quote
paul w Posted January 13, 2009 Posted January 13, 2009 How much coolant did you put back in?Sounds like heater matrix to me though.I'll give you a penny for the car! Quote
ste91 Posted January 13, 2009 Posted January 13, 2009 Pour petrol over yourself. Strike a match. Instant warmth. Quote
redz11 Posted March 2, 2009 Posted March 2, 2009 lol i got the same problem my blower works but only blows out cold air.. if anyone culd help us much appreciated. Quote
