Bildo Posted March 9, 2009 Posted March 9, 2009 Basically as the weather was nice yesterday I figured I'd find some good driving roads and give the Starlet a decent run for a change. Ended up accidentally making a wrong turning and ended up more or less offroad. (TomTom's and country roads don't mix well.)Next thing I know the rear of the car dips into a massive hole, which seemingly had a perfectly placed brick behind to smash into my exhaust.Rock 1 - 0 Nur SpecNow I need to decide whether to have a go at knocking the dent out myself (Most probably badly) or get it done professionally. Either way I'm more or less resigned to the fact it's unlikely it'll be perfectly round again. Quote
Kennedy Posted March 9, 2009 Posted March 9, 2009 Ahh man thats unlucky..if you do it yourself just take your time n don't wack it Quote
Bourkey Posted March 9, 2009 Posted March 9, 2009 Ouch!! I doubt it will probably be round again but you could ask someone to do it for you. The chances are you will make it worse by doing it yourself.Bourkey Quote
Asad Posted March 9, 2009 Posted March 9, 2009 I`d put a cloth over and gently bend it back with some pliers.....or you could go to a exhaust place and ask them to see if they can make it any better? Quote
Bildo Posted March 9, 2009 Author Posted March 9, 2009 Ahh man thats unlucky..if you do it yourself just take your time n don't wack it Yeah, it will require a lot of patience, it's sodding hard though so it probably would involve whacking it!Ouch!! I doubt it will probably be round again but you could ask someone to do it for you. The chances are you will make it worse by doing it yourself.BourkeyYeah, that's my main concern, if I was to give it a shot myself and not have it right, then decide to take it to a company for them to see what they can do just for them to say, 'Well we could've fixed it before you screwed about with it..'Meh.. My bung for it arrived in the post today aswell, wonder if that'll ever fit now. I`d put a cloth over and gently bend it back with some pliers.....or you could go to a exhaust place and ask them to see if they can make it any better?I thought about that, I intially thought it was a lot "pointier" than it is, so it may be possible to try and bend it.Think I'm gonna get advice from an exhaust place before I try myself though. Quote
tucka Posted March 9, 2009 Posted March 9, 2009 i would get it fixed properly man, nice system be a shame to f**k it up anymore! prob heat it up and get it bent back so u could neva tell. Quote
Mikey Jay Posted March 9, 2009 Posted March 9, 2009 Bill, get down PipecraftThey might be able to sort it for you Quote
jezza Posted March 9, 2009 Posted March 9, 2009 If they can't reshape it. Maybe a machine shop could turn it into a slash cut by chopping off the bent bit. Just a thought. Quote
ste91 Posted March 9, 2009 Posted March 9, 2009 You could probably get that almost round again.You'll need a cylinder shaped thing to shape it to... been a few years since I did metal work at college I can't remember a fucking thing lol... Quote
liam2368 Posted March 10, 2009 Posted March 10, 2009 you could fix that in seconds,just take your time and do not use a metal headed hammer. Quote
jimmy77 Posted March 15, 2009 Posted March 15, 2009 get the angle grinder out n cut it back , or cut it on an angle id do tha because im r.a.f lol Quote
Dan Evans Posted March 15, 2009 Posted March 15, 2009 best thing to do if you do it yourself, het the end of the exhaust up, hit it outwards with a rubber mallet, the get something metal in a cone shape, and hit it in the exhaust, aint hard to do mate, that happened to mine a while ago. Quote
SooperD Posted April 3, 2009 Posted April 3, 2009 mine was flattenend on the bottom where someone reversed over a kerb in Japan.. I use a nice pair of pointy nose pliers and just gently ease it around bit by bit until its close to circular. Can hardly notice it on mine. Quote
Bildo Posted April 3, 2009 Author Posted April 3, 2009 Forgot to update this thread, sorry guys.Thanks for all the advice, I decided to attempt to get it fixed professionally in the end but all he did was got out a chunky set of pliers and got it pretty much rounded. I then got some smaller pliers and a rubber hammer when I was at home and now it looks pretty much spot on again.Worry over! Quote
