laurenceharding Posted April 23, 2009 Posted April 23, 2009 has anyone on here throttle bodied a 4EFE? whats involved?parts?Cost? Quote
Mikey Jay Posted April 23, 2009 Posted April 23, 2009 Joz is going to be fitting individual throttle bodies on his 5efe soon.Isn't easy though, as a lot of work to make the setup, plus obviously need proper management as the air/fuel ratios need to be right as with throttle bodies a lot more air will be getting into the engine.Overall, isn't cheap, although not sure on what gains will be achieved, because as far as I know Joz will be one of the first people to have it done.(plus you will need to have supporting mods to make the most of it - exhaust mani and exhuast etc) Quote
rmsnoel Posted November 12, 2009 Posted November 12, 2009 It can be done on the cheap with a homemade manifold fitted with motorbike itb's like on homemadeturbo.com I had a 5e runnin with them with no management. Run rich as sin but it worked was the point.Dont start this project unless you are a commited diy mechanic. My advice, buy second hand emanage blue or other piggyback ecu for £250 then start boloting on manifolds and that. Quote
the quiet achiever Posted January 17, 2011 Posted January 17, 2011 Joz is going to be fitting individual throttle bodies on his 5efe soon.Isn't easy though, as a lot of work to make the setup, plus obviously need proper management as the air/fuel ratios need to be right as with throttle bodies a lot more air will be getting into the engine.Overall, isn't cheap, although not sure on what gains will be achieved, because as far as I know Joz will be one of the first people to have it done.(plus you will need to have supporting mods to make the most of it - exhaust mani and exhuast etc)hi did Joz buy a set-up from steed or is he going it alone i`ve just finished fitting a set brought from steed who originally had them fitted to a 5E-FE i believe . i acheived a miserly 10% HP gain but i have some issues with the set-up & would love to talk to someone who has a similiar set-up to compare votes lyle Quote
Jozinobi Posted January 17, 2011 Posted January 17, 2011 Hi LyleMy set made up by threepot many moons ago.I never fitted the setup and went have since went FTE.Its the fueling you need to sort and even an emanage does not have enough adjustment, standalone would be best.Which area/s are you having issues with?Joz Quote
the quiet achiever Posted January 17, 2011 Posted January 17, 2011 Hi LyleMy set made up by threepot many moons ago.I never fitted the setup and went have since went FTE.Its the fueling you need to sort and even an emanage does not have enough adjustment, standalone would be best.Which area/s are you having issues with?Joz there seem`s to be a drop in vac the tuner advised that the small cone filters fitted are choking the set-up i also have a fueling issue but i don`t know what influence it had on power it seems that if you richen in 1area it leans somewhere elsew istn`t enough adj in software i`m running a microtech LT-10do you know what gains i can expect ?? i only got 10% i need to know the critical length of runners so i can tidy up set-up i thought i would construct an airbox with trumpets i want to know what is critical in this ?? (the cone filters are so noisy when it hits the power band ) any info you can offer is appreciated who else has done any development with ITB`s??lyle Quote
EPilot Posted April 29, 2012 Posted April 29, 2012 Hallo moite,I'm usin GSXR 600 K3 throttle bodies on my 5E-FHE,they space lovely with two threaded bars,using alloy trumpets that taper from 60mm to 40mm,the throttle bodies,taper from 38mm to 34mm and the ports are 30mm when converted to a circle on paper so it works out perfect I rekon,only problem is the throttle pos sensor operates the opposite way but this is a small issue,also a civic D series fuel rail is the perfect spacing to use as a takeoff for the vacuum to the servo off the injector holes and polishes up nicely!! Quote
nathan87 Posted April 29, 2012 Posted April 29, 2012 (edited) I'm running triumph tt600 Bike throttle bodies on my 4efeStill using standard fuel rail and injectorsBut will be fitting bigger injectors with malpassi fuel regulator/>http://i122.photobucket.com/albums/o249/nathbmx2005/b8b1d93b.mp4/>http://i122.photobucket.com/albums/o249/nathbmx2005/8f367f42.jpg/>http://i122.photobucket.com/albums/o249/nathbmx2005/b8e326bc.jpg Edited April 29, 2012 by nathan87 Quote
siren676 Posted April 29, 2012 Posted April 29, 2012 Hallo moite,I'm usin GSXR 600 K3 throttle bodies on my 5E-FHE,they space lovely with two threaded bars,using alloy trumpets that taper from 60mm to 40mm,the throttle bodies,taper from 38mm to 34mm and the ports are 30mm when converted to a circle on paper so it works out perfect I rekon,only problem is the throttle pos sensor operates the opposite way but this is a small issue,also a civic D series fuel rail is the perfect spacing to use as a takeoff for the vacuum to the servo off the injector holes and polishes up nicely!!Have you got pics of this setup? Are the throttles a circle or oval at the top?This is my setup im about to try on my 5e-fhe. The throttles are off a zx-6r.Just unsure if the silicone joiners will try to collapse. Quote
nathan87 Posted April 29, 2012 Posted April 29, 2012 Mine tried to collapse all the timeHad to move the bodies near the manifold flange and cut the joiners down to stop it Quote
siren676 Posted April 29, 2012 Posted April 29, 2012 I'm hoping to keep the throttles pointing upwards so I can make an airbox that will be fed by the bonnet scoop.If they collapse i'll have to get some metal 90° runners put on, could probably scavenge some from the tubular mani I had to butcher to get the flange. Quote
LukeSR Posted April 29, 2012 Posted April 29, 2012 Good to see a few people trying throttles on 4efe's now! Quote
the quiet achiever Posted April 29, 2012 Posted April 29, 2012 hi have posted previously to this post now got them set-up @ least working that i can drive it airbox fitted Quote
the quiet achiever Posted April 29, 2012 Posted April 29, 2012 notice much gain? hi nothing much HP-wise bur great throttle response can work the red-line alot more easily& quicker but not good on STD motor Quote
bobby boy Posted April 30, 2012 Posted April 30, 2012 Not that I know of mate. Why? Where's the best place to start when doing an itb conversion? Quote
Asad Posted April 30, 2012 Posted April 30, 2012 Sort the vac/tps out and your away, you can mess with fueling/runner length etc later when its up and runningVac isnt that hard to figure out take inspiration from the honda girls and get a small vac tank...tps can be modified to fit depending how handy your are with metal work and the provisions your itbs have for one.... Quote
nathan87 Posted April 30, 2012 Posted April 30, 2012 I cut the old vac pipe off the old plenum, left a bit on the end so it had like mushroom on one end then drilled into my manifold and chemical metal'd it in place, obviously there are better ways of doing It. I just made do with what I had Quote
