interloper393 Posted May 16, 2009 Posted May 16, 2009 Can anyone recommend some valve springs to use for a 5e turbo build to prevent the valve float? id rather solve the problem than not rev past 7300rpm`s lol.. cheers Quote
interloper393 Posted May 16, 2009 Author Posted May 16, 2009 id just rather be safe than sorry because if valve float does happen i cn end up wrecking the head and as there no too expensive to buy id rather fit some uprated ones if possible.. this is more the test build at the mo, in the future i plan on a fully forged engine with a 300+bhp aim :surrender: Quote
ste91 Posted May 16, 2009 Posted May 16, 2009 Normal 4EFTE valve springs will be fine. All 4E/5E heads are virtually the same except the 4EFTE has stronger springs and the 5EFHE has "better" cams. Quote
interloper393 Posted May 16, 2009 Author Posted May 16, 2009 well i used the 4e head but change over to the 5e cams so i should`nt get valve float then?Thats kewl then lol Quote
Spuddy Posted May 16, 2009 Posted May 16, 2009 The 5E isn;t as rev happy due to the max piston speed being exceeded lower down the rev range than a 4E. Also with the longer stroke the bearings can take a serious kicking if your reving to much. valve springs are the least you should be worried about :surrender:IMO don't rev past 7500 and keep the stock springs. U wont need to go past 7500 anyway. Quote
interloper393 Posted May 16, 2009 Author Posted May 16, 2009 so its 7500rpm? didnt think it was as high as that bud, well thats one less problem to sort lol.. Quote
ste91 Posted May 16, 2009 Posted May 16, 2009 Well the 5EFHE revs quite high so I wouldn't worry about the bottom end either, it's not like it's revving 8-9-10k rpm, so I wouldn't worry about it aslong as you've got atleast 4EFTE valve springs. Quote
Spuddy Posted May 17, 2009 Posted May 17, 2009 Well the 5EFHE revs quite high so I wouldn't worry about the bottom end either, it's not like it's revving 8-9-10k rpm, so I wouldn't worry about it aslong as you've got atleast 4EFTE valve springs.The bottom end on a 5E won't take as much abuse at high rpm as a 4E but if your staying under 7500rpm she'll b grand. Quote
