the little light that comes on when you use your handbrake comes on when i use my brakes. used to be just hard braking but not its more or less whenever i push the pedal. any ideas. sounds like a dodgy wire or somethin but i thought id check n see what people say :). cheers
Russell
the little light that comes on when you use your handbrake comes on when i use my brakes. used to be just hard braking but not its more or less whenever i push the pedal. any ideas. sounds like a dodgy wire or somethin but i thought id check n see what people say :) . cheers
Russell
that light can also mean your brake fluid level is low and it might be going under min when you press the pedal
cheers guys. think it could be the pads because i was just in the bay and the fluid is at high so ill check the pads. excuse to buy new brakes :)
cheers
Russell
  • 1 year later...
