thanks to anyone that can help me
been reading up lots about this and just want to make sure i got this right :lol:
i am doing a standard turbo change on my ep91 putting another standard one on and not touch the boost doing the gaskets and decat
do i need to change the standard mainfold or not is it just a preformance mod or are the standard one easy to crack
thanks to anyone that helps me ;)
Yes mate it's definately worth changing the manifold, you will get better performance.
Also you have probably read about it already, there is a restriction on runner #3 which is no good for the 3rd cylinder.
The design of the manifold is important and also the material, it's no good getting a cheapy stainless steel one off ebay they will just crack but at the same time some manifolds can be quite expensive. I think the SPS ones are good value and I've seen loads of positive comments about them on here and TGTT.
hello steve my good friend how u doing?
nice one for the help
but if i am leaving it standard do i defo need one on it mate
i read somewhere that someone was runing 1 bar on a standard one mate
thanks buddy :lol:
If you're not running higher than standard boost it should be ok.
na not touching the boost just restricted it mate
i thought it would be just put a new gasket on it mate
Should be fine bud but if you have ever seen the standard one i'd change it to be safe :lol:. The standard one is mega restrictive i think.
Bourkey
