conal'sr Posted July 11, 2009 Posted July 11, 2009 do they just bolt on, or do they have to be glued on? Quote
SiCaln Posted July 12, 2009 Posted July 12, 2009 well to do it like it came out of the factory, u have to drill holes - but they can be bonded on quite successfully Quote
cleanshavenllama Posted July 12, 2009 Posted July 12, 2009 I put glanza skirts on my SR, i just used self tappers along the bottom and at each end, that alone has give them a strong hold Quote
Dan_SV Posted July 13, 2009 Posted July 13, 2009 tiger seal would be fine i would have thought, but if you wanna be sure you cud put a couple of self tappers in as well. Quote
rob_bower Posted July 13, 2009 Posted July 13, 2009 yeai used self tappers along the bottom and at each end with a small bead of tiger seal along the top edge!! Quote
Dan_SV Posted July 13, 2009 Posted July 13, 2009 yeai used self tappers along the bottom and at each end with a small bead of tiger seal along the top edge!!thats how you do it! Quote
conal'sr Posted July 13, 2009 Author Posted July 13, 2009 thanks for all your helpits much appreciated Quote
jonnygt Posted January 2, 2010 Posted January 2, 2010 i will take note of this comes in handy for when im fitting mine lol Quote
rob_bower Posted January 2, 2010 Posted January 2, 2010 yea thats the easiest way just take your time use some masking tape if needed to hold them in place for a short while when you first stick them on to give the tiger seal time to bond!! Quote
jonnygt Posted January 2, 2010 Posted January 2, 2010 yea thats the easiest way just take your time use some masking tape if needed to hold them in place for a short while when you first stick them on to give the tiger seal time to bond!!tiger seal is FTW ill invest in some when i get round to fitting them Quote
