japcarmaniac Posted July 28, 2009 Share Posted July 28, 2009 is there a bigger throttle body or another intake manifold that will fit to the 4EFE from another toyota or other? Quote Link to post Share on other sites
Starlet__SR Posted July 28, 2009 Share Posted July 28, 2009 The 4efte throttle body and the corolla manifold will both fit on the 4efe.Damien Quote Link to post Share on other sites
japcarmaniac Posted July 28, 2009 Author Share Posted July 28, 2009 i heard the 4efte throttle body is only 1mm bigger. what corolla manifold are you refering to? Quote Link to post Share on other sites
ste91 Posted July 28, 2009 Share Posted July 28, 2009 The 4EFTE TB will not fit as it has different sensors or something.The 7AFE TB will fit though. Quote Link to post Share on other sites
japcarmaniac Posted July 28, 2009 Author Share Posted July 28, 2009 from the corolla? ill check that out. is that the throttle body or both mani and TB? Quote Link to post Share on other sites
japcarmaniac Posted July 28, 2009 Author Share Posted July 28, 2009 cant find anywere thats states the diameter of the 7AFE TB. Quote Link to post Share on other sites
ste91 Posted July 28, 2009 Share Posted July 28, 2009 Have a search on the forum I saw a post about it a couple of days ago... Quote Link to post Share on other sites
japcarmaniac Posted July 28, 2009 Author Share Posted July 28, 2009 ok it seems the 2nd gen 4efe TB bore is 45mm and the 1st gen is 50mm. the 4efte is also 50mm so will prob try that route. Quote Link to post Share on other sites
ste91 Posted July 28, 2009 Share Posted July 28, 2009 The 1st gen 4EFE is very very similar to the 4EFTE.As far as I am aware it has the same sensors so you will have the same problem. I *think* the 7AFE throttle is 55mm but you'll have to check. Quote Link to post Share on other sites
japcarmaniac Posted July 28, 2009 Author Share Posted July 28, 2009 i read the thread about the 7AFE and aparently theres some modification to be done to get it to fit. Quote Link to post Share on other sites
Asad Posted July 28, 2009 Share Posted July 28, 2009 Have a read, the 7AFE is a good few mm bigger http://www.ukstarletclub.com/forums/index....557&hl=7AFEI took all the observations down as i was comparing both Quote Link to post Share on other sites
Mikey Jay Posted July 29, 2009 Share Posted July 29, 2009 The 5efhe throttle body is 50mm too for reference Quote Link to post Share on other sites
japcarmaniac Posted August 24, 2009 Author Share Posted August 24, 2009 7afe throttle body will arrive tomorrow. ill let you know how it goes. Quote Link to post Share on other sites
ste91 Posted August 24, 2009 Share Posted August 24, 2009 Nice, what other mods do you have? Quote Link to post Share on other sites
japcarmaniac Posted August 24, 2009 Author Share Posted August 24, 2009 im planning to get the throttle body then from there order the correct size silicone and aluminium tubing to make a tidy custom intake around the engine and down to the gap between the coolant bottle and the rad. wrapping the manifold and using reflective tape on the exposed part of the intake over the manifold. then book my car in to get the badly blown peeshooter exhaust off and a full decat stainless. although this will have to wait as the missus is due and dont want to take the car off the road lol. the only other thing ive done is 40mm drop, mr2 spyder alloys, clear indicators, fli components, jap plates and just a general tidy up. i would realy like to get rid of the gay interior, ive got some semi taylored covers and they fit quite good but the seats are still crap. i had a prelude before so i miss the snug hold the bucket seats give you. Quote Link to post Share on other sites
Asad Posted August 24, 2009 Share Posted August 24, 2009 Are you using a corolla inlet or standard one? Quote Link to post Share on other sites
japcarmaniac Posted August 24, 2009 Author Share Posted August 24, 2009 standard. ill prob need to port match it some how. not sure if the corolla intake mani will bolt up to the 7afe TB. ive not even looked into it. would it? i dont think this will make any more difference unless the corolla mani tubes are larger thus alowin more air to enter the cylinders. does anybody know if the turbo cams would offer any advantage with the extra air due to the longer valve lift duration? Quote Link to post Share on other sites
ste91 Posted August 24, 2009 Share Posted August 24, 2009 Get a Corolla manifold the standard one is a pile of wank.It will bolt up fine, if it fits the standard it will fit the Corolla one.As far as I know the turbo cams are the same or almost the same as the normal 4EFE cams, if you want bigger cams you could try finding some 5EFHE cams or you'll have to get some made. Quote Link to post Share on other sites
Steve GT Posted August 24, 2009 Share Posted August 24, 2009 not too sure on this one but i think the turbo cams are higher lifting than the standard ones but again im not too sure can someone confirm this please Quote Link to post Share on other sites
glanza179 Posted August 24, 2009 Share Posted August 24, 2009 i have heard same rumor / read it somewhere, i have a set of turbo cams sat in my mates garage so if this is the case i may be tempted to drop them in when i do the cam beltJim Quote Link to post Share on other sites
japcarmaniac Posted August 24, 2009 Author Share Posted August 24, 2009 Get a Corolla manifold the standard one is a pile of wank.It will bolt up fine, if it fits the standard it will fit the Corolla one.As far as I know the turbo cams are the same or almost the same as the normal 4EFE cams, if you want bigger cams you could try finding some 5EFHE cams or you'll have to get some made.is there a specific one? Quote Link to post Share on other sites
Marc0 Posted August 24, 2009 Share Posted August 24, 2009 For cams, use the aftermarket FTE cams that the company Speedvision (USA) delivers for the FTE. Should give some nice result with some extra fueling mods in a 4E-FE Quote Link to post Share on other sites
Asad Posted August 24, 2009 Share Posted August 24, 2009 The FTE cams are different...theres a post by rmsnoel stating so. Quote Link to post Share on other sites
Steve GT Posted August 24, 2009 Share Posted August 24, 2009 i knew it lol Quote Link to post Share on other sites
Asad Posted August 24, 2009 Share Posted August 24, 2009 Im sure with fte cams, bigger throttle body, filter, aftermarket exhaust mani + pipe work, glanza s injectors + rail + ecu etc the magic 100+ is easy......just no one has ever tried it. Quote Link to post Share on other sites
