thank you all!
@siren676: nice result!
@nastyrash2003: ist a 5e-fe head with the 5e-fe camshaft, i havent seen any difference betwen it and my 4e-fe head.
the compression ratio is now about 10,3 : 1 i didnt do much work
here some more pics:
before
after
and i make the gasket fit better, this is how it looks before :)
the dyno result is not very good because it runs to lean, now i mounted a fuel pressure regulator and it is much better
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
i hope so
before i mounted the fuel pressure regulator it runs with about 17 kg air - 1kg fuel at full throttle mutch to lean now its nearly perfekt with about 14 kg (at 3.6 bar fuel pressure)
i try to mount and map the EMU as fast as possible, and then one more time on the dyno :(
i hope you understand my gruesome english :)
  • 1 month later...
