Painting My Rocker Cover
  • 3 months later...
  • 5 weeks later...
do you need any sort of heat resistant paint for this ? have mine off at the mo too.. can u just use any spray paint.. anybody recommend anything in particular ??
cheers
glen
As your rocker cover will get hot
You will need heat paint
As Chanelle said "it will peel"
Engine paint or caliper paint
if you get the high temp spray paint id go for some laquer aswell if you dont want it t be matt. can have a look at my build thread before i done the engine swap for my inlet manifold. have a before and after shot of the laquer
