  • 3 weeks later...
i dont know how it is with the ukdm loom, but the JDM glanza's' ecu wont work plug an play with the german loom.
do the ukdm 4e-fe have a knock sensor?
mmmmm indeed, i believe rob is correct. i started to gather some of the parts for this a few years ago but abandoned ship.
at the very least, would the JDM ECU not be expecting higher RON fuel?? which would make life miserable for a start!!!
Phil.
I checked my ECU this morning, its got two plugs.
@Phil - yeh was thinking that myself about the RON, I'll just wap in some Shell V Power
@RobSR - I have very little knowledge on cars, what would be the reason the car wouldnt run? Ive ordered the glanza S ecu along with the fuel injectors, would I need something else?
Also with this setup of ecu and injectors would I need to upgrade my FPR or would the stock one I have be fine? (I have searched for this already but couldnt find a definitive answer) thanks
Adam
Adam
you need the fuel rail of the glanza's', because of the higher fuel pressure.
do you have a knock sensor?
I went and had a look. From what I can see I don't think I have a Knock Sensor, although i might have missed it. Do you have a knock sensor?? And does this have any effect using glanza 'S' ecu, fuel rail, injectors??
Adam
Uk non turbos don't have knock sensors. As for why it doesn't work, it could be anything.. Knock sensor/ think Glanza s has a different idle control valve/ it has a completely different ignition setup/ immobiliser etc
Adam
yes! now i have one, i took one of the 4e-fte because the glanza's' ecu needs the signal.
you also need a shielded wire,
i took one like this:
http://www.notebooksbilliger.de/image.php/...+cinch+kabel+2m
and build out of it a knock sensor loom :rolleyes:
When plugging a JDM unit into a UKDM vehicle it'll start but not idle. Never really looked heavily into it as Alan's plans snowballed but I figured the ECU was missing a signal from somewhere. It would probably take us to look at the ECU pin-outs and see what's different.
Jay
Could it be what motion is talking about, a signal from the knock sensor??
Adam
Jay
yea that's what I meant was just been lazy lol. It's the same with the corolla one aswell !
  • 2 weeks later...
Jap NA redlines higher as well, the uk engine would not handle it because of the different valve springs. you would get bounce.... or so im told :)
somthing i looked into. to be honest guys, mite just be easier putting a 5efe in, with a few other mods and get similar power that way
we know that can be done, and its not overly expensive. can be done on a tight budget. need a slight idea what ure doing though
  • 2 months later...
If you had opened up the ecu's you would see that the pinouts are different, or rather the same but in different positions, there are only 6 extra wires for the jdm glanza s into a uk 4efe.
Im making a field extension harness to move the wires about for testing. Really to fit a glanza s ecu into a uk 4efe all you need is fte turbo inlet manifold with sensors and the knock sensor as they are same as glanza S. The different wires are just for the cold idle thing so in theory it should work without it. I'll post the pinouts and that later. Mines not fitted ive only started on the harness, thanks to terrx on tgtt for the how to open up the loom plug thread.
This is different to my pinouts on the uk4efe, but use this template to make to pinout lists, one for your 4efe and one for your jdm ecu. Then go to the loom plugs and on the bottom side pop open the lock plate 1mm or so. Then using a stiff sewing needle or similar, push up the plastic retainers and pull out the pins; one at a time. Then reinsert them to match the jdm ecu. You'll be missing a few so these are where you need to add the knock sensor and any other missing sensor wires. If this sounds like alot of work you really shouldnt be messing with electrics or engines, stick to spoilers and bodykits please. DO NOT just plug in a new ecu to see does it work without first checking the pinouts inside.
4E-FE UK 75BHP ECU pinout
Pin Name Wire color Explanation
Connector 1
1 RSC Gray Rotary Solenoid Close - Cold Idle Speed Control
2 NSW Red Neutral Starter Switch
3 THW Green-Black Water Temparature Signal
4 PIM LightGreen Pressure Intake Manifold
5 THA LightGreen-Black Intake Air Temparature
6 IGT Black-White Ignition Timing
7
8 IGF Yellow Ignition Feedback from the ignitor coil
9 NE- Blue Part of the IIA (Intergrated Ignition Assembly)
10 OX White Oxygen Sensor (Lambda Sensor)
11 STA Red(M/T) or Red-White(A/T) Engine Cranking Signal (Starter Switch)
12 #10 Green Injector Pulse 1 & 3
13 E01 White-Black Computer Ground
14 RSO Black-Red Rotary Solenoid - Cold Idle Speed Control
15 HT Pink-Blue Heated Oxygen Sensor
16 E2 Brown-White Sensor Ground
17 VTA
18 VCC LightGreen-Red Throttle Position Sensor (pin 1)
19
20
21 NE + Green RPM Signal
22 NE - ~ ~
23 ~ Vacuum Switching Valve
24 E1 Brown Computer Ground
25 #20 Yellow Injector Pulse 2 & 4
26 ~ ~ ~
Connector 2
1 ~ ~ ~
2 BATT White-Green Switched Battery Power (+12V) (EFI Main Relay)
3 in my opinion
4 FC Green-Red Circuit Opening Relay (Fuel Cut)
5 ELS Green Electrical Load Signal System Taillight Relay
6
7 TE2 White-Blue Check Connector
8 TE1 Gray Check Connector (Diagnostics)
9 +B Black-Yellow Switched Battery Power (12V)
10 W Green-White Warning Light
11
12 AC1 Pink A/C Switch Signal System (12V to Aircon Computer)
13 SPD Violet Speed Signal
14 ACT Black-White A/C Cut Control System
15 IMI
16 VF Green-Yellow Check Connector Outputs
4E-FE GLANZA S ECU pinout
Connector 1
#2 TE1
#7 IGF
#8 FAN
#15 TE2
17 VTA
#19 NC
#20 CF
21 NE Green RPM Signal
#22 IPV
#23 KNK
#26 HT
Connector 2
#1 SEL --------????????????????
#3 CCO Unknown Check Connector Outputs
#5 ELS3
#6 ELS2
#7 ELS4
#8 NSW
11 EGW Unknown Catalytic Converter Temparature Warning Light (Combination Meter)
#15 ELS1 Unknown Electrical Load Signal System
tHE CONNECTORS MARKED WITH '#' ARE THE DIFFERENCES BETWEEN UK 4EFE AND JDM GLANZA S
Ok Ive identified most of the pinouts but I need help with these few. What do these abbrevations stand for
EGW
SEL
NC
CF
IPV
Most of the differences in pinouts seem to be the diagnostic ports connectors, meaning the car should run without them, I'll swap round the distributor and igination pins tomorrow and try her out
