adee-ep Posted August 8, 2009 Posted August 8, 2009 bought my glanza about a week ago as a project from b19 yul , went to drive it todday but the turbo isnt spoiling what could be the problem any help is welcome cheers aidan Quote
bucketep91 Posted August 8, 2009 Posted August 8, 2009 what actuator are you running? is it still clipped on to the wastegate arm? Quote
ToyotaTech15 Posted August 8, 2009 Posted August 8, 2009 The actuator on Stuarts glanza is knackered,The spring is weak and doesn't hold boost.Pretty sure that's all it needs mate,Tried to pm you about the radiator but your inbox was full,Did you get the oil cooler pipes sorted ok?Gary Quote
adee-ep Posted August 8, 2009 Author Posted August 8, 2009 that actuator is changed and still isnt boosting atol. no power what so ever gary. 60mph top!!its cool man. yhe got the breather pipes sorted.what else could cause zero boost? Quote
ToyotaTech15 Posted August 8, 2009 Posted August 8, 2009 Oh right, thought that would have fixed it.Mightbe the turbo itself, if you have changed the fmic and new actuator that rules them out, I also found burst vacuum hoses on the turbo pressure sensor side, they were also replaced but that only sorted a dodgy idling problem.Might need another good looking at, it's a weird problem.Gary Quote
