It feels like sand,or mud
I've also get alot of coolant built back up into the expansion tank and sometimes comes out of the overflow pipe after a motorway journey or a good thrashing.
Oil in the coolant?..Need a new Head Gasket?
Could just be a build up of crap from the system aswell..try flushing it all out and adding some new clean coolant in.
i would say your headgaskets fucked bud, is there all mayo in the oil filler cap, i would get a compresion test if i was you bud
it's not the oil filler cap it's the rad cap... when was the coolent last checked/changed?
Thanks for all your inputs.
I did a compression test 2 weeks ago and came back around 150 on all 4 cylinders.
I'v just flushed and empited out the radiator and looking down inside the rad, the fins are covered with that gunk. I'v added toyota red mix inside.
Im waiting for a new rad cap to see if it resolves this lift of coolant up the expansion tank, and it dont syphon back into the radiator when cools down :thumbsup:! . (It started overflowing when it was on the rollers)
^^i have a standard rad cap you can have if you cover postage?
Thanks dude but i ordered one last wed from tm-developments. Should be with me today or tomorrow!!
i agree with rick might just be a build up of shite in the system
take all pipes off and flush them all out, empty the water bottle and flush all that out, put fresh water in, bleed the system to stop air locks and should be fine
