DavidAshton Posted September 24, 2009 Posted September 24, 2009 Nahhh i dont have a pic looking into the turbo flange but im sure rick does, i guess he does make the with a really good tight seal, ive herd nightpager ones that dont leak so im sure its easy to improve on there design to make one that seals accordingly. Quote
Danturbo4311 Posted September 24, 2009 Posted September 24, 2009 I run an external wastegate with a screamer pipe on my gt28 turbo, running 25psi I've extended the pipe so it sits where my side exit exhaust used to be in the front bumper sounds does sound good when the turbo gets on boost Quote
y3Lo Posted September 24, 2009 Posted September 24, 2009 ZERO point in having one of those "Screamer/Decat" pipes, you can say they won't blow, but by design you cannot get a 100% seal and will blow either just a little or badly. Also screamers on internally-gated turbo's sound rubbish. Screamers only work properly on external wastegate set ups.He're a vid from inside my 180sx running a TD06-20g with a screamer: sorry but i had to lmao at the only quote to your vid 'I was there watching. Brilliant day out. What car were you in? Suck my cock.' < what the fuck? lol Quote
