Marck glanza V Posted October 2, 2009 Posted October 2, 2009 hi today i have fitted a external wastegate manifold and wastegate a FMIC a decat and a front mount air filter and i have no boost atall checkedd allmy intercooler piping but couldnt find any leaks any ideas what it could be causing this?? Quote
ste91 Posted October 2, 2009 Posted October 2, 2009 Have you checked all your intercooler pipes are on properly? No leaks? Quote
micky boy Posted October 2, 2009 Posted October 2, 2009 Have you checked all your intercooler pipes are on properly? No leaks?have you checked the vacum pipe that gos from the actuator to the turbosometime they split also what actuator have you got?? Quote
StarletRick Posted October 2, 2009 Posted October 2, 2009 if it isnt leaking anywhere, its going to be the wastegate. silly question... is the spring in it? Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 havent actually checked if theres a spring in it (will do that today)its a new pipe im using for the wastegatei have checked my intercooler pipes about 10 times Quote
Sparky Posted October 2, 2009 Posted October 2, 2009 Weld the wastegate flap shut on your turbo?? Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 yeh got a bracket made upturns out i think my turbo just shat itself because there is a bit of oil in the compressor housing Quote
Glanza_cl Posted October 2, 2009 Posted October 2, 2009 you would still get boost mate, just alot of smoke with it. has to be something to do with a lack of pressure... something to do with the external wastgate possible Quote
ste91 Posted October 2, 2009 Posted October 2, 2009 Is there any movement in the boost gauge needle at all or does it just stay where it is? Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 checked the wastegate couldnt find anything wrongthe needle moves from - .65 to 0 then once the car gets higher in the rev range it feels like it might be hitting fuel cut Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 also checked for play in the compressor wheel and theres none and it still rotates Quote
Glanza_cl Posted October 2, 2009 Posted October 2, 2009 do any of the three green lights on the dash light up? Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 do any of the three green lights on the dash light up?nope Quote
micky boy Posted October 2, 2009 Posted October 2, 2009 its must be something to do with the external wasgate like cl said lack of presure Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 its must be something to do with the external wasgate like cl said lack of presureany ideas what??????? Quote
Bildo Posted October 2, 2009 Posted October 2, 2009 I know you said you've checked for leaks in the pipes, but I had the same issue. I was certain none of them were leaking but I just took them all off and made sure I did everything 100% perfect second time around, felt where the pipe was in the hose etc. When I put it together it boosted perfectly.Might be worth doing that as it'll be easier than most things that need doing with the wastegate/turbo. Quote
micky boy Posted October 2, 2009 Posted October 2, 2009 any ideas what???????im not that clued up on external wastegates are they adjustable? Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 im not that clued up on external wastegates are they adjustable?no they are not adjustable i have a 0.7 bar spring in it i have taken my intercooler pipes off and refitted them quite a few times still no lucktook it for another drive and on the downrev get a strange rattle from the turbo area ?? Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 i also removed the pipe for the wastegate just to see what happened and there is no difference Quote
Sparky Posted October 2, 2009 Posted October 2, 2009 I know what it is.Take the filter relocation off and drive it I bet yiu have put the stainless pipe too far down the silicone pipe and its restricting the air getting into the turbo, the same happened to me when I fitted mine Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 already tried that with no luck Quote
Marck glanza V Posted October 2, 2009 Author Posted October 2, 2009 so am i. think im gonna have to take it sumwhere Quote
Glanza_cl Posted October 2, 2009 Posted October 2, 2009 silly question but are all the turbo studs done up tight? is there any noise when you drive and try and come onto boost?no whooshing sounds? any noises at all... apart from the rattle you stated? Quote
