chr15_7_t_ Posted October 26, 2009 Posted October 26, 2009 curently taking my engine out of my gt..can anyone help me with a wee question..just want to know if i will manage to get the engine out without having to drop the gearbox? or is ther enuf room to get it out any help is good help lol Quote
rorenapier Posted October 26, 2009 Posted October 26, 2009 Engine and box can be removed as one, through the top or bottom, which ever you prefer. Quote
chr15_7_t_ Posted October 26, 2009 Author Posted October 26, 2009 i was meaning more can i take the engine out without taking the box aswel? is ther enuf room to remove it:/ Quote
rmsnoel Posted October 26, 2009 Posted October 26, 2009 The fastest easiest way to remove engine to split the inner cv ie cut of the cable tie and lift the engine and gbox as one out the top as it goes up the drives come out of the cups which stay in the gbox, an hour to reomve looms and manifolds airbox radiator and carbon canister. Means you your not messin about tryin to centre clutch and bolt up in car to gbox. Completely remove gbox side mount and brackets and lift engine slighty higher on driver side and turn alittle anticlockwise was the handiest way I found. Apoligys if Im tellin to something you already know. Video it and we'll start a @How fast can you remove/refit your engine competion. We could have a singles and double league, oops totally brainwaved there n got carried away Quote
chr15_7_t_ Posted October 26, 2009 Author Posted October 26, 2009 i like your idea of the fastest hahaha...i wasnt to keen on touchn the box because then its more to come off :/...i no prob would be easier the way you saybut is it stil possibe the way im wanting to? even if i was to take the engine out first then wory about the gearbox after...i havnt got my replacment engine yet so im not to worried about how long it will take Quote
Steve GT Posted October 27, 2009 Posted October 27, 2009 trust me dude I've done an engine change take the engine and box out as a whole, split them outside the car then put your box an the new engine before you put it back in. it can be a bit of a bitch locating the box onto it again when its in the bay. plus doing it utside the bay means you can bang the engine and box straight in and connect back up quicker in my opinion Quote
Russleh Posted October 27, 2009 Posted October 27, 2009 ye fek trying to do get the box to go back on when your trying to put the engine back in. When i done my engines i dropped the engine onto a tire through the bottom then lifted the whole car and slip it out. easy peasy ( ish ). centreing the clutch is fairly simple aswell just play with it till you can get the box back on and bolts in the take it off then tighten up the clutch. so i recommend just taking the whole box out . Quote
chr15_7_t_ Posted November 12, 2009 Author Posted November 12, 2009 well i got the engine out and it was surprisingly easy..cant see it been as easy to put the new one when it arrives back in. im confident with everything apart from lining up the clutch lol never done this before? Quote
