i have a universal back box on mine. not too difficult all you need is a step down pipe cuz the bore for the exhaust is usually much larger than the starlet pipe, this will cost around £10 - £20. all i did was chop the original standard pipe before the back box and joined it on there. then made a bracket to hold it in place. may require the assistance of trained machanic, but it can be done.
prob not the best plan if your main objective is performance, something about back pressure??? im no expert. will make a wicked noise though.
hope this helps.
keirz
