Hi guys
Hope that a few people can help me, im planning on doing a conversion at some point next year and would like some info.
1) I herd that there may be a problem with the abs if i was to strip a glanza for bits
2) Do i have to have to change the rear light loom and the fuel pump loom as im not sure which plugs are on the glanza loom.
3) As far as i am aware what i will need for the conversion is;
Full engine including gearbox, clutch etc
Dash loom/engine loom
ecu
indicator stalks
GT rear axel
exhaust
speedo cluster
cheers for reading
help would be appreciated
chanelle x
dont think it matter about the shafts to be honest. i asked the same thing and dub seven replied saying he still uses shafts from an n/a so should be good for a few more hp.
Hi guys
ecu
indicator stalks
GT rear axel
exhaust
speedo cluster
cheers for reading
chanelle x
1. My glanza loom has all the abs plugs on it, dont use it, strip the loom down and remove all the abs stuff.
2. I think it depends on what year your ep is, mine was a 98, and i used 96 glanza looms, and i needed the floor loom (pump rear lights etc).. youll need to do a bit of wiring on the fuel pump aswell, as the connection on the hanger is completly different.
3. You dont really need a turbo rear axle, it looks better, but you wont really notice the difference if you adjust the drums, 80% of the braking is done by the front...may be worth putting GT/Glanza callipers/disks on the front though, as they are slightly larger. You can use your na gearbox if you not going for a lot of power, gear ratios are shorter aswell...Again wouldnt worry about shafts, i measured them compared to gt ones, and the na's were 1mm thinner.
