My gearbox has started to grind into 3rd at high revs/boost.
It doesn't seem to be any other gears but if I do a fast-ish change into 3rd it seems to be slipping into gear and making a fast grinding noise.
If I granny change (Fully depress clutch then notch it in at a "1 and 2 and" kind of speed then lift the clutch its fine.
Do you think its the syncro ring on 3 or something else.
Not really a technical whiz with gearboxes so would appreciate any help/ advice.
If it is the syncros, how expensive are they and where do I get them from (dealer on here or do I have to be bum raped by my main dealer?)
Cheers
Steve
bump for some assistance!
hi mate. sounds like 3rd gear syncromesh. happens alot in these gearboxs. mine had it in 2nd. got it rebuilt with 1st, 2nd, 3rd gear syncromesh. selling it if you decide you need another one mate
Cheers
Where would I buy new syncros from?
Have I got to be robbed by Toyota or do any of the dealers do them?
Plus is it a hard job to do?
Steve
  • 6 months later...
Old thread I know, but my car has the same problem from time to time.
Would a different box he cheaper than getting it re-paired?
Cheers
Adam
Cheers
Adam
I would alway opt for, repair your own or replace with new as you never know what condition used parts are in like gearboxes/ engines till there fitted. then its to late you've spent the money.
What other boxes could fit???
Was thinking maybe a 1.0 litre micra box or something similar with shorter ratios??
Im no gearbox expert so any help would be much appreciated :)
Adam
