BAZ2CRAZY Posted November 22, 2009 Posted November 22, 2009 Ok so. long story short;Welded my decat because it was cracked. The flange warped slightly so wasnt 100% flat. Upon re-fitting it, i was tightening up one of the nuts, slowly pulling the flange true. Then SNAP goes the stud.Ive never been in this situation before... and im so pissed off at myself.My questions are: Am i completly fucked?Can i remove the stud?If so, shall i remove the whole lot? (turbo,manifold etc) then tackle it.What shall i do about the warped flange on the de-cat?Mitch Quote
WallaceGlanza Posted November 22, 2009 Posted November 22, 2009 Those studs can be removed easily and new one's bought from toyota, not really a big problem. Quote
BAZ2CRAZY Posted November 22, 2009 Author Posted November 22, 2009 Thats all i wanted to hear lol. Would you advise me to remove the whole turbo setup and tackle it?TaarMitch Quote
riko666 Posted November 22, 2009 Posted November 22, 2009 just remove the stud with some pliers, buy a new one, put it in finger tight, and its done. Alternatively, you can use a bolt if it'll fit with the downpipe! Quote
WallaceGlanza Posted November 22, 2009 Posted November 22, 2009 Thats all i wanted to hear lol. Would you advise me to remove the whole turbo setup and tackle it?TaarMitchNo. You should easily be able to get the stud out with the turbo in place, just get some mole grips on it. Quote
Russleh Posted November 22, 2009 Posted November 22, 2009 you need studs like the ones on mine. they come off themselves sometime its great you should manage to do it no problem with the turbo on. Quote
BAZ2CRAZY Posted November 22, 2009 Author Posted November 22, 2009 Ok, Ive given up completely for the evening, so il give it another crack tomorrow.Think i need a torch and a big hammer to flatten the flange.hmmMitch Quote
andy.i Posted November 22, 2009 Posted November 22, 2009 easy peasywd40 it then put one nut on half way down, then another nut on and put them tighten them against each other, then use the back nut to twist the stud out. thats if youve got enough thread.if not, mole grips and a hammer Quote
BAZ2CRAZY Posted November 22, 2009 Author Posted November 22, 2009 Yeah, i get you... only theres no thread lol.Thanks for the replys .Now... any one got a decat flange nice a flat before? Think thats why it snapped to be honest.Mitch Quote
andy.i Posted November 22, 2009 Posted November 22, 2009 if there isnt room for mole grips, i see there is a bit of thread left, put a nut on and weld it Quote
Starlet__SR Posted November 22, 2009 Posted November 22, 2009 Want me to come round and have a look Mitch? Looks like it can be removed in situ, or I can always take it away and do it if you wish?Damien Quote
Sparky Posted November 22, 2009 Posted November 22, 2009 As said not a major problem you can get a pair of decent pliers on there or weld a nut to it and undo it (I had to do that to my turbo hotside pipe before!!)If you got loads of bolts lying about you could try fitting one of them other than getting a new stud from Toyota Quote
Starlet__SR Posted November 22, 2009 Posted November 22, 2009 And if you want I can always make a set of studs up out of high tensile steel tooDamien Quote
BAZ2CRAZY Posted November 23, 2009 Author Posted November 23, 2009 Thanks for the help. I was just worrying that the stud was designed to... stay in.Damien- il see how it goes mate, but i might take you up on that offer il post up how its going. Quote
Dan507 Posted February 20, 2015 Posted February 20, 2015 Bump - are these studs the same as the turbo/Manifold ones? Quote
